20 Most Recent GE JKP20 Electric Single Oven Questions & Answers
Why oven cools automatically after preheat
Others are having problems with this unit. Have the manufacturer support their product and fix it. It should be covered if it is new. Don't delay in hounding them. Time will expire and you will be left with an expensive ordeal.
11/2/2013 6:35:39 AM • GE JKP20... • Answered on Nov 02, 2013
manual
manual
Looks like the keypad is malfunctioning. Getting
unplug for five minutes and it will reset
11/19/2010 12:20:18 AM • GE JKP20... • Answered on Nov 19, 2010
I have a GE jkp20 wall oven and the door is
you need to get a tech ,you cant correct this
9/10/2010 3:02:51 AM • GE JKP20... • Answered on Sep 10, 2010
'79 GE oven lower bake coil not heating after replaced w/switch.
good day,
hope this link below will solve your problem.
kitchen appliances
7/31/2010 3:24:38 AM • GE JKP20... • Answered on Jul 31, 2010
I have to turm the oven off at the braker box. it
This is usually a keypad stuck key error, usually caused by a bad keypad or sometimes caused by your control board.
F7 usually means a stuck key on the keypad. I've also seen it caused by a greasey buildup on the keypad connector into the control board. Try pressing each button on the keypad followed by cancel. See if the buttons are registering with the control - should get a beep or some function (execpt up/down buttons need a cook or time function enabled first). If one of the buttons seems inoperative it may be stuck, in which case you probably need a new keypad.
Best Regards, Diana
6/16/2010 4:55:50 PM • GE JKP20... • Answered on Jun 16, 2010
GE profile 27
two diff relays for them replace relay board
5/6/2010 6:16:33 PM • GE JKP20... • Answered on May 06, 2010
My ge specta bottom heating coil is not working.
I just took apart mine and found the same problem. Broil and range work fine but nothing when the bake function is used. I pulled the heating coil and it showed open (infinite resistance). This could well be your problem too. Pull out the drawer on the bottom and you'll see where the coil connects. Pull it and check resistance with an ohm meter. If it shows open, that's probably your problem. It was pretty easy to pull and shouldn't be too tough to reconnect either.
12/25/2009 4:57:44 PM • GE JKP20... • Answered on Dec 25, 2009
Hello, My oven fan runs but the heating element
From the symptons, I would say that the oven elementg has failed, and needs replacing.
Trust this helps you.
12/5/2009 7:19:29 PM • GE JKP20... • Answered on Dec 05, 2009
How do I replace my GE electric Bake coil?
unplug unit,remove 2 screws at rear of oven where element comes thru wall, unscrew terminals,then reverse the procedure and then turn power on
11/4/2009 11:27:19 AM • GE JKP20... • Answered on Nov 04, 2009
Oven comes on for no reason followed by the start beep
yes you can kill the power and lock out the box with a pad lock for safety. the panel is attached by screws usually on the bottom of panel. lower and seperate the control panel ribbon from the erc (electronic range control). without removing any other components leave ribbon loose and replace panel. turn power back on. if the beeping does not recur, the control panel probably has a stuck key. if it does resume the erc is faulty
5/17/2009 11:56:38 PM • GE JKP20... • Answered on May 17, 2009
2answers
My ge spectra stove bake element is not heating
I have a GE Spectra stove. The top element over heated and broke in half.
4/20/2009 9:08:14 PM • GE JKP20... • Answered on Apr 20, 2009
2answers
JKP20-27 SELF CLEANING OVEN OPTION
Hold the stp/clear button in ??
2/16/2009 11:58:22 PM • GE JKP20... • Answered on Feb 16, 2009
Oven turns on by itself
only thing i could say here is replace the control or clock its real name is an eoc electronic oven control now the part is under a five year warrenty but you have to pay labor and use some one that is authorized for ge warrenty work check your owners manuel for second to five year warrenty and go to ge web site to locate servicer in your area http://www.geappliances.com/service_and_support/service/
6/5/2008 4:27:43 AM • GE JKP20... • Answered on Jun 05, 2008
Installing a new lightbulb
it screws off, make sure you replace it with an appliance bulb.
2/20/2008 8:58:07 PM • GE JKP20... • Answered on Feb 20, 2008
Why does it say "Clean Door" during the self-cleaning procedure?
Never ever use the Self Clean feature. All it exists to do is to keep the makers in a steady stream of sales of spares. The temperature is 800 to 925'F. The parts can't handle it. Try turning off at the breaker overnight to reset.
Why You should Never Run A Self Clean Oven Cycle & A ...
General Appliance Service https://www.generalappliancesvc.com > why-you-should... Jan 29, 2020 - A self-cleaning oven is a feature on many modern ovens that burns off cooking spills and splatters with an extremely high temperature (932 F° or ...
Self-cleaning oven
Wikipedia https://en.wikipedia.org > wiki > Self-cleaning_oven A self-cleaning or pyrolytic oven is an oven which uses high temperature (approximately 932 °F (500 °C)) to burn off leftovers from baking, without the use ... ‎Pyrolytic process · ‎Alternative technologies · ‎Catalytic cleaning
Self-Cleaning Oven: 6 Reasons to Stop Using Feature ...
FIX Appliances CA https://fixappliances.ca > 4-reasons-stop-using-self-cleani... Feb 2, 2024 - Auto-cleaning, also known as "pyrolytic cleaning," operates by heating the interior of the oven up to 500?C. During this process, grease is ... ‎How Self-Cleaning Ovens Work · ‎Major Parts Damage ..
2/27/2024 4:13:13 AM • GE Ovens • Answered on Feb 27, 2024
GE Double Oven. How do I remove the front glass so I can clean the inside of glass
You remove the door and then split the inner and outer parts of the door. clean the glass with Easy Off spray, rinse well, polish and put it back together. The videos should help as they all work to a theme.
How to Clean Oven Glass-Inside, Outside, and In Between!
The Happier Homemaker https://thehappierhomemaker.com > Recipes > Cleaning Aug 24, 2022 - Spray outside glass with vinegar and wipe down with paper towels. · Clean inside of the oven glass with a scouring pad using the "hack" below. ..
11/24/2023 7:51:22 PM • GE Ovens • Answered on Nov 24, 2023
Where do I locate the fuse for GE Profile electric range Model J BP79 A0B2AA?
The fuse for a GE Profile electric range model JBP79A0B2AA is usually located behind the control panel, near the power cord. You may need to use a putty knife or thin flathead screwdriver to gently pry the control panel away from the wall before accessing the fuse.
10/31/2023 3:04:19 PM • GE Ovens • Answered on Oct 31, 2023
GE JKP20 Electric Single Oven Logo
Popular Tags
28 questions posted
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Ovens
  • GE Ovens
Most Popular Question
oven fan runs but heating element
  • Ovens
