I need to buy a replacement of 326B1230P001 GE double oven. Will other brand, e.g. Whirlpool?s with...
(More)
I need to buy a replacement of 326B1230P001 GE double oven. Will other brand, e.g. Whirlpool?s with the exact dimension work? Any difference in voltage requirement?
el reloj está activado y funcionando pero no se puede modificar la hora. el horno...
(More)
EL RELOJ ESTá ACTIVADO Y FUNCIONANDO PERO NO SE PUEDE MODIFICAR LA HORA. EL HORNO NO SE PUEDE UTILIZAR DE NINGUNA MANERA.
I was cleaning the top oven, this had been running for an hour or more. Got hungry, started...
(More)
I was cleaning the top oven, this had been running for an hour or more. Got hungry, started preheating the bottom oven. The top oven (in the middle of a cleaning cycle) came up with an error code F9. I let everything cool down, seems to be fine now. I looked at the solution for code F9 in the previous thread. Do I really need to get a tech out here to look at the door lock switch and wiring???
GE Model JBP 77G S1AA, Serial GL229649G was working fine until a power outage... now the clock &...
(More)
GE Model JBP 77G S1AA, Serial GL229649G was working fine until a power outage... now the clock & oven do not work... I could care less about the clock, but I'm not sure why the oven does not work ??? Is there a reset button somewhere??? Any ideas??? The range top, however, works fine.
I JUST CALLED FRIGIDAIRE AND GOT INSTRUCTIONS FOR SELF CLEANING: 1. TAKE OUT THE RACKS UNLESS YOU DON'T MIND THEM TARNISHING 2. TURN THE...
written by NATALIENATAL
Equipment is Whirlpool double oven RBD305PDS14 built-in. After a very stormy summer 2007, I thought a power surge may have zapped the control...
written by babrown
Before you bake something, your oven needs to be heated to the proper temperature. While it takes only a few seconds to turn on your oven, it can take...
by wikihow
Honest, Dependable, Available & Professional!
Appliance Parts Supply! We Ship Nationwide. Our Phones Answered From 7 AM - 9 PM CST Mon - Sat.
Over 30 Years Experience!
972-859-0929 - Call us NOW!
www.accurate-appliance-service.com
