20 Most Recent GE JVM1542 Microwave Oven Questions & Answers
A relay sometimes gets bad connections inside and needs replacing. The door switches turn everything on and off, likeely one of the switches is bad
GE JVM1542... | Answered on Nov 25, 2013
If keypad is locked, hold down clear button for 3 seconds to unlock keypad.
GE JVM1542... | Answered on Jun 24, 2010
Is the light on?
Things that it could be.
Could be a door switch.
Or it could be a stuck fan relay
Or worst odf all it could be a bad Timmer Keypad board. Not worth fixing because they cost to much.
GE JVM1542... | Answered on Jan 14, 2009
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order a universal type from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
GE JVM1542... | Answered on Dec 02, 2008
The problem is damage to the control circuit board. This damage is usually caused by removing or installing light bulbs without disconnecting the oven from the power line first. We regularly repair these GE / Samsung smart boards for this problem for customers from across the country for $32.50. We have an important file called "safety.txt" which you can find by doing a search for "microwave safety.txt" on Yahoo.com. It's important information to consider before proceeding. When the varistor fails, it will be shorted. That will cause the whole oven to be "dead". It's almost certainly fine.
GE JVM1542... | Answered on Oct 02, 2008
If you have plug-in type watt meter, you can check the power draw of the oven when it is heating and it isn't. The magnetron is the primary power consumer of the unit, and by comparing the difference of power you can tell if it is the magnetron. Most likely your intuition is correct.
GE JVM1542... | Answered on Jun 09, 2008
I assume you're talking about the hood fan which ventilates the cook top and blows air through the grille across the top. If so, it's okay to use the microwave with that not working, but if you boil something on the stove, an external fan is definitely needed to keep mositure from going up into the microwave controls. If the cooling fan INSIDE the microwave (behind the keypad) is not working, then you do NOT want to run it unit it is fixed. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
GE JVM1542... | Answered on Apr 10, 2007
If you have Acrobat Reader you can see an exploded diagram of this model here: http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00018000/00018081.p01.pdf Ref # 110 and 115 are thermostats and ref # 27 is the hood thermal cutout. One of these devices is likely bad. You can order them via GE online at http://www.geappliances.com/shop/prts/ or via Sears online at http://www3.sears.com You should also be able to find them at local appliance parts stores. Here are the GE part numbers and prices: TCO HOOD REF# 27 WB27X10789 $11.50 THERMOSTAT,BIMETAL REF# 115 WB27X10506 $21.75 THERMOSTAT- BIMETAL REF# 110 WB27X10788 $12.75 Good luck.
GE JVM1542... | Answered on Oct 30, 2006
There many from different manufacturers. You will have decide. All measurements are listed so measure yours .
GE Microwave... | Answered Yesterday
GE JVM1542 Microwave Oven Logo
25 questions posted
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Microwave Ovens
  • GE Microwave Ovens
Most Popular Question
not heating
  • Microwave Ovens
