20 Most Recent
Patton U2-1487 Floor / Box Fan Questions & Answers
Wiring on a 3 speed rotary switch for a fan (cord
put the 2 white wires together then try one of the other wires from the fan to the black power wire,if to slow try the other wire if that speed works tape off the other wire . it should be white to white and red to black green is ground
My dog ate the cord to the fan I need to know how
Hi mlh9188
You can replace your cord that was eaten by your dog very easy.
Disassemble your fan.
Be sure to mark how the fan is assembled with an awl or sharp instrument to scratch an alignment scratch on the outside of the motor case before you disassemble it....maybe even take a picture
Once you have the fan disassembled to the point that you can get to where the wire that was chewed is connected to the fan, you will disconnect the wires from the plugs,sockets,etc...take another picture before disassembly.
Take the old cord with you down to your local hardware store,loews,homedepot,ace hardware,etc.
Tell the person in the electrical dept what happened, and he will fix you up with a new set up.
Come home install the new cord and plug...keep away from dog...
Please take time to rate me
I need a 3 speed switch for model: u2-1487.
For Patton
fan model U2-1487 120v 60Hz 1.5 amps. the 3-speed switch Patton does not carry replacement parts anymore. I suggest look some aftermark switch and check
your wiring and the diagram that come with the switch. You might have
the hot wire (power wire usually black in color) wired directly to
the motor. Normally the switch will have a common wired which should be the hot wire, then it should have a wire for each speed.
Double check your wiring and wiring diagram. I'm Sure It was just a small oversite. Personally, I suggest you evaluate the cost-benefit of changing the switch or replace the equipment.
Good luck.
I was trying to install a fan control switch on my
Thr issue you are having you need to look on the motor and see if there is a diagram but you have to use the grey and white for a capacitor because i have an older fan that has no capacitor. and use the red for high
