Home
My Products
Sign In
All Products
Honeywell
Humidifiers
Problems with Honeywell Warm Mist HWM-255 Humidifier?
Add to Warranty Manager
Search inside
Knowledgebase
Troubleshooting and Support
Post a New Problem
honeywell warm mist humidifier shuts off
My humidifier flashes green and yellow lights, then shuts off.
1 Solution
Manual
I need a manual for the HWM 255. Do you have any idea how I can procure one?
2 Solutions
Unit turns off Mid Stream
My machine turns on fine, runs for about 5 minutes, then shuts off showing that the water tank is empty??? When the tank...
1 Solution
Water leak
The water tank empties completely when placed on the unit (it should drip water as needed).
1 Solution
Noisy humidifier
My humidifier makes a great amount of noise. is it fixable?
1 Solution
do i need to oil my Humidifier from time...
do i need to oil my Humidifier from time to time?
1 Solution
The fan motor need to be replaced, can i...
The fan motor need to be replaced, can i do it by myself?
1 Solution
View All
Unsolved Support Problems
Post a New Problem
Water tank of your humidifier
Hey, I'm not sure what's wrong with your humidifier, but in case you are unable to fix your humidifier and decide to...
Post a Solution
control panel
After i turn on unit and set desired humidity level it flashes 90% as the current humidity level which is impossible. ...
Post a Solution
Tips & Tricks
Post a New Tip
Be the first to Post a New Tip
WikiManual
Post a New Chapter
Be the first to Post a New Chapter
Manuals & Guides
Post your Manual or Guide
Be the First to upload Manual or Guide
Specifications
Key Features
Overall Tank Size
3 Gallons
Technical Features
Humidity Control
Humidistat
Warranty
Warranty
5 Years
Honeywell Contact Information
Main support number
800-328-5111
New Products from Shopping.com
More offers
Sponsored Links
shah9
Let one of our
Experts Solve
your Problem
DO YOU WORK FOR
HONEYWELL
Register as STAFF
Top Experts
dgorslin
Kimi
windman
Repair Service
Find Humidifier Repairman Near You:
Advertise Here
powered
by
Get this Widget
