FixYa.com
Pelonis HB210B Ceramic Compact Heater
All Products > Pelonis > Heaters
Problems with Pelonis HB210B Ceramic Compact Heater?
Search inside Pelonis HB210B Ceramic Compact Heater Knowledgebase
Troubleshooting and Support
Solved Problems for Pelonis HB210B Ceramic Compact Heater RSS Feed Post a New Problem
I use several small space heaters...
I use several small space heaters annually, as well as a couple of fans and have to replace these almost annually...
1 Solution
I just installed a gas heater and I am...
I just installed a gas heater and I am concerned that it might not be big enough to heat my pool effectively. It seems...
1 Solution
Furnace will not come on, need heat!
The Furnace worked fine last year and now it does not? I am sure that it is something simple but I have no idea how to...
1 Solution
Pilot light goes out!
Hello, I own a procom heater Serial # 3640534 QJ002 The pilot light has a bit of a yellow flame. Anyway,...
1 Solution
Cadet heater quite working
I've got a Cadet C122 wall heater that quite working. There's 240V to the heater and continuity across the reset switch....
1 Solution
Pilot light will not stay on when egnition...
vokera excell 80 boiler. Pilot light will not stay on when egnition switched is released! Pilot light keeps going off...
1 Solution
reddy heater
getting fuel and spark but won't ignite
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeCompact
FeaturesPower Indicator, Oscillating, Thermostat, Timer
Power SourceElectric
Heating ElementCeramic
Fan ForcedFan Forced
Safety Features
Safety FeaturesTilt Switch
Power
Power1,500 Watt
BTU5,200 BTU
Dimensions
Depth7.25 in.
Height11 in.
Width10.5 in.
Weight4 lb.
Warranty
Warranty3 Years
Pelonis Contact Information
Main support number1-866-876-4332
Email supportservice@mideausa.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
