20 Most Recent ICOM Informatique iTECH iQfive iQplus Icom IC-F3GS, IC-F3GT, IC-F4GS, IC-F4GS. BP209, BP222 Compatible Two Way Adapter... 2-Way Radio Questions & Answers
I use the ICOM OPC-478 cable along with the ICOM F3GS software. In order to use the OPC-478 cable with WINDOWS 7, it will be necessary to go to the site
www.icomamerica.com
choose support (not option 1) and look for the updated driver package for WINDOWS 7. When that has been downloaded and installed, it will be necessary to go into that part of the control device manager and change the port to "COM2".
I am now able to program both my IC-F3GS and the IC-F4GS.
Try contacting ICOM AMERICA
www.icomamerica.com or look on eBay.
ICOM... | Answered on Feb 01, 2013
www.icomamerica.com
firstly you will need to access the menu if you cannot these may be programmed using the proper software ,you will be able to unlock it then or give it to someone that can program it for you
ICOM... | Answered on Dec 03, 2010
Charging a battery requires two components. A working charger and a functioning battery. The concept is simple. A battery charger must output more voltage than the battery does, and at an acceptable current level. First determine the battery output from the ID sticker, then measure the charger output. It must be 1 or 2 volts more than the battery output. If the charger is working, charge the battery overnight. If the battery does not charge or runs down quickly, the battery must be replaced. All batteries have a limited number of charge cycles. The most common problem with Ni-Cad batteries happens when they are re-charged before they are completely discharged. Recharging a half used Ni-Cad sets up a short term memory and the battery discharges faster than normal.
ICOM... | Answered on Dec 30, 2016
Copied this from their manual:
The lock function prevents accidental frequency changes and accidental function activation. q Push (looks like f) , then push [7• ] to turn the lock function ON. •" " appears. (looks like f) To turn the function OFF, repeat step 2 above. •" " disappears.
http://www.icomamerica.com/en/products/avionics/handheld/a6/default.aspx
ICOM... | Answered on Sep 21, 2016
I really, really suspect your programming.
ICOM... | Answered on Feb 22, 2015
I thought it was the speaker
ICOM... | Answered on Feb 11, 2015
In the USA, repair and service of a radio frequency transmitter requires a 1st, 2nd, or 3rd class FCC license. The other bad news is the radio probably uses a solid-state chip for tuning, so special tools will be needed to remove and install a new chip. This is best left to a factory repair center.
ICOM... | Answered on May 30, 2014
No, it cannot be "narrowbanded".
ICOM... | Answered on May 19, 2014
any ham radio store can fix them. or can send to the factory. and the good thing about amateur radio is individuals cant charge you to fix it.. LOL.
just for price of parts.
ICOM... | Answered on Feb 04, 2014
battery pack already exhausted or your charger is defective, check your charger by using voltmeter, if there is voltage output more than your battery voltage that means your battery needs replacement.
ICOM... | Answered on Dec 24, 2013
The 705 will operate on (8) frequencies in the 446Mhz range and (5) in the 464Mhz range. The 708 operates on 446Mhz. Please note that the links provided mention they operate in "public frequency band" of South Africa. These radios were not intended to be used in other countries. See below for more.
In the U.S.(and many, many other countries), the 420Mhz - 450Mhz frequency range is set aside by the FCC (and other bodies) for licensed operation by amateur radio operators. Portions of the 460Mhz range is set aside by the FCC for use by Public Safety Agencies - mostly local police and fire departments. In the U.S., the Family Radio Service (FRS is 462Mhz) is an unlicensed band and General Mobile Radio Service (GMRS is 467 Mhz) requires a licensed.
As you might have guessed, unlicensed or unauthorized transmissions are ILLEGAL. You may be fined, imprisoned or both if caught by the FCC. If using these radios in a location other than South Africa, consult that county's communication authority BEFORE transmitting. You cannot transmit legally in the U.S. with these radios.
ICOM... | Answered on Nov 19, 2013
Try looking up the user manual at www.mods.dk they have many manuals. Otherwise you may be able to get the manual from www.icom.com.
ICOM... | Answered on Nov 05, 2013
ICOM Informatique iTECH iQfive iQplus Icom IC-F3GS, IC-F3GT, IC-F4GS, IC-F4GS. BP209, BP222 Compatible Two Way Adapter... 2-Way Radio Logo
Popular Tags
6 questions posted
Top ICOM Informatique Radio Communications Experts
eradiostore
eradiostore
ka4iup
ka4iup
Robert L Kershaw
Are you an ICOM Informatique Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • ICOM Informatique Radio Communications
Most Popular Question
ndlcomhow program
  • Radio Communications
