FixYa.com
Slant Fin FE-1500 Coil / Ribbon Baseboard Heater
All Products > Slant Fin > Heaters
Problems with Slant Fin FE-1500 Coil / Ribbon Baseboard Heater?
Search inside Slant Fin FE-1500 Coil / Ribbon... Knowledgebase
Troubleshooting and Support
Solved Problems for Slant Fin FE-1500 Coil / Ribbon Baseboard Heater RSS Feed Post a New Problem
I use several small space heaters...
I use several small space heaters annually, as well as a couple of fans and have to replace these almost annually...
1 Solution
How do I change my heater from natural gas...
How do I change my heater from natural gas to propane gas?
1 Solution
Won't shut off when reaching preset temp
The heater will not react to the temperature setting and shut off when the preset temp is reached. It had been working...
1 Solution
boiler will not shut off
My boiler has been working fine for a few years, recently it does not shut off form some reason and I have to do it...
1 Solution
2000 watt baseboard heater is making loud...
The electric baseboard heater is mounted onto a wooden wall with four screws near the ceiling. It is connected to a...
1 Solution
Heater won't fire
I have a kerosene heater that won't fire. I replaced the coil and some pump parts. It's getting fuel and spark and seems...
1 Solution
I have no manual and no clue
We have a Dyna Glo Pro #RMCKFA170TDGP. The shop guys say it wont ignite and I have no manual to troubleshoot the...
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
TypeBaseboard
Power SourceElectric
Heating ElementCoil / Ribbon
Fan ForcedNon Fan Forced
Power
Power1,500 Watt
BTU5,120 BTU
Dimensions
Depth10.4 in.
Height5.25 in.
Width34.6 in.
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
