20 Most Recent Canon Pixma MX922 Questions & Answers
Many errors occur while using the printer. Error B200 is the common errors encountered in the Canon Printers. I have also faced this issue. than i follow the steps:-
1. Firstly, turn OFF the Power button.
2. Open the printhead bay.
3. Turn ON power mode.
4. Wait for print carriage to start moving to the left and let it go past halfway.
5. Before print carriage reaches left-hand side shut the cover.
6. Leave the Printer turned on.
Visit How to Fix Canon Printer Error Code B200 Call 1 800 237 4319 if still, the issue occurs.
Canon Pixma... | Answered on May 09, 2019
Try turning off both the computer AND the printer. When it restarts, the two will reset and recheck and communicate.
Canon Pixma... | Answered on May 01, 2019
out paper problems are usually caused by a worn pickup roller for a replacement solution on a pickup roller
Canon Pixma... | Answered on Apr 29, 2019
you have two reset machine 5 times by unplug unit wait 5 min plug back in & let it do the funky chicken thing. Do this 5 times
Canon Pixma... | Answered on Mar 01, 2019
After re installing software I still got the same message.
So I went into the menu on the MX922. Then to Setup. Device settings. Then reset settings. Then Reset ALL. Works fine again.
Canon Pixma... | Answered on Jul 31, 2018
You better buy a new cartridge, or you could fix that open the cartridge on your printer device.remove the cartridge and broom with a Kleenex.If you need the driverpleasehere Canon PIXMA MX922
Canon Pixma... | Answered on May 05, 2018
When the message "5100 / 5101 Printer error has occurred. Turn off power then back on again. If problem persists, see the manual." is displayed, the behavior of the print head holder is interrupted.
Do you see a jammed paper or foreign material?
Did you install the print head properly?
Please see the following for detail.
If the problem persists, contact the service center for repair. Cause 1. Is there a securing material for the holder inside the printer? Summary There may be a securing material for the holder inside the printer.
(This material must be removed before using the printer.)
Open the Top Cover, then remove the securing material for the holder. See Also Cause Summary [ With the securing material ]
[ Remove the securing material ]
Then, close the cover, and turn ON the printer again. See Also Cause 2. Is there a jammed paper or foreign material inside the printer? Summary Stop printing, then push the power button of the printer to turn OFF the printer.
Open the Top Cover of the printer; then,
  • If there is a jammed paper or foreign material inside the printer, remove them.
See Also Cause Summary [ The printer with the Top Cover opened ]
( Paper jam )
After checking the above items, push the power button to turn ON the printer again.
CAUTION
When removing the jammed paper or foreign material, take extra care so that you do not touch the inner parts. Or, it may cause another printing problem.
See Also Cause 3. Is the ink tank properly installed? Summary If the ink tank is not properly installed, it interferes with the operation of the print head.
See the following images to get an idea of proper print head position. See Also Cause Summary [ When the ink tanks are not properly installed ]
The ink tank is not set firmly.
The ink lamp is not turned ON. See Also Cause Summary [ When the ink tanks are properly installed ]
The ink lamps are turned ON.
CAUTION
Always remember "Do not touch the Print Head Holder while it is moving."
Wait until the Print Head Holder automatically stops.
Do not even attempt to stop/move the Print Head Holder by holding it.
Canon PIXMA MX922
Since you do not have a dial tone, please ensure that the line coming from your telephone source is plugged into the LINE jack on the unit. If you are connecting a telephone or answering machine to the unit as well, you will want to plug them into to the EXT jack on the unit. Please ensure that the unit is turned off when connecting the telephone line and telephone/answering machine to the unit. More information on connecting the lines and devices to your computer can be found
Once these items have been verified, if you still are unable to hear a dial tone when you press the HOOK button on the unit or are unable to send a fax, please call or email us using one of the methods on the page for further assistance.
Canon PIXMA MX922
turn off printer and unplug for at least a day
Canon Pixma... | Answered on Jan 09, 2018
If you wantCanon Printer Customer Service Phone Number, then you can contact with us Canon Printer Tech Support Phone Number#1877-778-8@9@6@9.We are always here with tech team for your help. For further information Click: https://goo.gl/ZYjDqq
Canon Pixma... | Answered on Mar 28, 2017
Canon Pixma MX922 Logo
183 questions posted
Clive
Clive
old marine
old marine
View Most Popular
PIXMA Canon
  • PIXMA Canon
Most Popular Question
get manual canon printer mx922 printer
  • Office Equipment & Supplies
