20 Most Recent
Broderbund Creating Keepsakes Scrapbook Designer Deluxe for PC Questions & Answers
How do i install it from the cd
Double click the "My Computer" icon on your desktop or use your start menu to navigate to "Computer" or "My Computer."
From there you should see a list of drives connected to your computer. Select the one that is your CD/DVD drive (it may have the icon of the CD inserted).
Double click that and it may either begin the installation or open a folder to the drive. If the installation begins then simply follow the prompts. If it opens a folder to the disc then look for something resembling the following:
Setup
Install
Autorun
Or it may be the name of the program itself. It will likely have an "exe" extension (although your computer may be set up not to show filename extension). If you see one that seems like the right name double clicking will start it and you can then follow the prompts to install it.
I am trying to reinstall Creating Keepsakes after
It would seem like your CD is damaged.
You can try fixing it by copying the content from the cd over to your computer then run the setup.
you also want to make sure that you run the setup with administrator rights.
I have the Broderbund Creating Keepsakes Designer
The Broderbund.com site has manuals available for download on its support page. What I did was searched for manuals in the search area. If you do not find it on the site for free download, you can contact Broderbund on their contact us page and ask them if the manual is available for a charge. I did search for "guide" and your software product, which came up with a software installation guide showing screen shots, and there is a printable version.
Barbara-Ann
Path not found when choosing a projecdt
It's not that it's not supported by Vista its the fact that the software does not support 64bit operating systems and there is no updated software for it either.
If you had a 32bit OS then it may work if you ran the program in XP mode.
Regards.
