20 Most Recent
Maxon SP-100G (4 Channels) 2-Way Radio Questions & Answers
Reprogramming a Maxon SP 100G?
Hello codeencrypt,
THE SP100G is essentially the same radio as the SP100U UHF business band unit that Maxon made at the same time, just pre-programmed for GMRS. I believe there is a programming kit for this radio (Model number: SPK400C) which may still be available for purchase from Maxon directly. Otherwise, your best bet is going to be contacting your local Maxon dealer to see if they have the capability to program he radio.
Best regards,
Ken
"Go Ahead. Use Us."
Maxon MCB 10 A
I'm not sure about your particular model but many CB radios use the microphone push-to-talk switch to kill the speaker while the radio is transmitting. If you don't have the correct microphone or if the cord has a broken wire it can cause the radio to have no sound. Another possibility is that the speaker is bad. There is probably an external speaker jack on the back of the radio. You could try plugging a different speaker or even an earphone in the jack to see if you get sound there.
Can the maxon SL55 V2 programmed for 144 -146 Mhz
GENERAL Performance Specifications R&TTE Directive 1999/5/EC Band VHF (V1): 136-162 MHz VHF (V2): 146-174 MHz UHF (U1): 400-430 MHz UHF (U2): 440-470 MHz Number of Channels 16 Channel Spacing 12.5kHz, 20kHz, 25kHz (Programmable per channel)
I have a maxon mcb-45w and need to rewire the mic
good luck . if you haven't wired it yet you may have to wire it by trial and error . I have one with no mic and I've been trying on and off for several years to wire one up . Not that its taken me that long ,I get the urge an I break out the radio and I work on the mic until I get frustrated then quit.
