20 Most Recent
Wagner 0503040 MODEL HT3500 Digital Heat Gun w/12 Settings from 250F to 1350F Questions & Answers
I bought new wagner model HT3500 a few years ago never used until now pulled it out of the box it does not stay running. is there a call back on them?
I was given a dead HT3500. Holding the power switch down made unit lights rapidly blink and motor start/stop.
However, before starting repair refer to the HT3500 recall notice.
http://www.cpsc.gov/en/Recalls/2009/Wagner-Spray-Tech-Recalls-Heat-Guns-Due-to-Fire-and-Burn-Hazards/
Assuming your gun isn't in recall, the repair involves dis assembly and replacing the 470uF 10V electrolytic capacitor on board (it is a tall cylindercal plastic covered part.) Replaced it with a 470uF 16V rated at 105*C. If you are handy with a pencil solder iron and solder removal tools, it is a 5 minute repair. Any electronics technician or ham radio buff can do this job.
Won't prime
Try to trouble shoot the problem by doing this:
clogged filter(s)
you did not clean paint out of machine properly on last use
the packings are worn and need to be replaced- it wont hold or build pressure- also that sprayer has a max tip size of .15
My procoat won't prime
The inlet valve is probably stuck. It is a flat poppet type, so you need to free it up. A Graco dealer should be able to supply a special small plastic bottle with a special top filled with their Pump Armour to do this job. Otherwise you can unscrew the inlet valve from the cup side to clean it out, but be careful not to lose the small spring. You should always flush Pump Armour through the ProCoat after use otherwise the passageways corrode
How much should good scaffold brick guards cost me?
These should be expensive, but they are nothing of the sort. You can pick up quality scaffold brick guards online for as little as £3.99. I use a company called
BrikGard because they use 100% recycled plastic scaffold brick guards. I like to be as environmentally friendly as possible without compromising quality or increasing the purchase cost too much. Given that their brick guards are so cheap and made from 100% recycled plastic, I feel safe using them. Also, anyone working on-site should consider using a brick guard because it offers that extra layer of peace of mind so you can get focused on the job without worrying about things like falling debris coming down and striking you. For affordable scaffold brick guards, I would check out BrikGard.
Removal Storage
If you are looking for a company who use latest equipments then i would refer you to appoint "bison removals" or "guildford removals". These two companies have excellent instruments to make your removal effortless.
