20 Most Recent Compaq Laptop Keyboard for HP Pavilion DV9000 - DV9700 Questions & Answers
there is no video card, this is not a desktop (cept my elite book)
your GPU is solder down chip, if its 2008 PC, then it has the solder balls failure. Nvidia failure. is this 2008 PC>? the service guide says 2007 ,so is 10 year old or 9 and has bad GPU chip, as most did.
in DOG years its, 100 years old.... few ever last this long....
this thing is old its not new,
all old laptops are trash, this old, they are like dog years.
no OS stated, so cant help much. lacking that key fact.
is it still running the original XP day1 new? or did you upgrade the OS and if not done right many things will fail, even wifi and video.
what wireless card? is it HP, card? USB card, where did you plug in said card (mini-pci slot inside?) yes i see it in the parts list.
they can go bad but I bet the driver was and is wrong.
the driver must match prefectly and these card that is tricky.
there were many models of cards made. so, yah,
i have special software scanner I use to ID all cards and all chips.
then i can match anything made.
The 9200 is now legacy, at HP , retired and no support this old.
It came with XP new, is that what it is now?
The drivers for all the cards and chips are not at HP now.
so getting all that to work right takes hard work.
here are the black screen steps, are you ready.
remove that old main battery they short, leave it out until its fixed.
power on, does no power on , and fan blows>?
are the vents clear of lint so it wont overheat.
does the HDD spin , heard.
any text on the screen ever.?
if you use a flash light to screen can you see data"?
if you torque the base gently or push ******* the J key
does the screen wake up?
I think its solder balls from hell. but ID have to strip it down
and do tests to prove that.
here is your serv. manual, (site search magic)
http://h10032.www1.hp.com/ctg/Manual/c01311536.pdf
here is the solder ball deal. 2007 to 2009
http://www.pcdied.com/monitors.html#solderball_hell
Compaq Laptop... | Answered on Aug 29, 2017
Make sure the PS or adapter you are using is good. If it does the same with another known working adapter or battery then it appears that the cmos on the mo bo is corrupted. U might try disconnecting the hard drive and optical drive to see if unit stays on. But if it still goes out then it is definitely the board and a faulty peripheral is not to blame.
If board is bad, time to go shopping since the repair is not really cost effective given the cost of the board and the high labor expense involved.
Compaq Laptop... | Answered on Jun 14, 2017
For me when I toggle the num lock key, this causes the issue you describe: jkll;uiop would spit out 123-456*. I am using a HP Pavilion DV9000 series laptop.
Compaq Laptop... | Answered on Mar 31, 2014
On my HP Pavilion DV9500 with Win7 64 bit (laptop was new in 2007 and had Vista), I have the same problem, and I press FN-insert/scroll key and this works as the print screen button. That's the function key together with the insert key, which is 2 buttons to the left of the print screen key.
numberpad on hp dv9000 Page 2 Hardware Canucks
I cannot solve your problem. However I have exactly the same problem with my DV9600. I can hook up an external monitor and use it as a desktop. Mine is also off warranty. I am curious if others have the same problem and if more people telling HP about this will have any effect.
Compaq Laptop... | Answered on Mar 22, 2012
The problem is the GPU, HP will fix it for free if it's less than 2 years old. You can check out www.msbin.com if it's over 2 years old. The guide will show you how to reflow the GPU with common household tool.
Compaq Laptop... | Answered on Mar 10, 2012
I assume you are using a version of Windows. If so, you will need to go to the control panel and reset the type of keyboard you are trying to use. This will most likely require loading a new driver for the keyboard. If you got a CD with the keyboard, there should be a driver for it on the CD. If not, you may find a driver on the internet ... try a google search for the name & model of your keyboard.
Compaq Laptop... | Answered on Nov 06, 2010
Follow these steps to fix the problem :
1.Turn off the computer press F8 when you turn on the computer you will get advance boot options on the screen.
- Select safe mode and the press the enter key twice
- the computer bill boot into safe mode
-when you get all the icons click on start in the search system restore and then restore it to a date when it was working fine. ( Select a date when your system was working fine).
This process will restart the computer automatically and you will get a message that it has been done.
This should fix the problem.
2.
If this doesnot then reinstall the video card driver and see if it helps.
you can do that by going to the manufacturers website then go to drivers and downloads and then by selecting your product.
Compaq Laptop... | Answered on Oct 12, 2010
A code 10 is usually indicative of a device that is not recognized by the computer, this could mean that is has failed, has become dislodged from its connector or the drivers are no longer valid or have failed to the point where they do not point the system to the device. Try downloading new drivers for the device. If that fails, try to remove the keyboard and replace with same or newer and check all connections. Below is the link to the service manual.
http://h10032.www1.hp.com/ctg/Manual/c01951704.pdf
Compaq Laptop... | Answered on Jan 15, 2010
That a nice computer you have there. Based on your description, my guess is you have a bad power supply.
About a $300 fix if you send back to HP. Which is what I had to do a while back.
Compaq Laptop... | Answered on Jan 07, 2010
By default Administrator account is disable in vista. while you are install window first user work as Administrator member...
Compaq Laptop... | Answered on Jan 05, 2010
Try holding F11 while booting, sometimes this triggers the recovery partition.
the only possable problem is the power source. so most likely your power converter box on the power cord has over heated, which is common, its expensive to replace though($70-85). if the problem continues take it to a shop don't try to repair the internal power converter yourself.
Compaq Laptop... | Answered on Nov 16, 2009
Hi:
The keyboards on laptops are somewhat fragile, and would be the first thing that should be tried. They are not too hard to change, and relatively inexpensive, about $15 on ebay. You could plug in a external, USB keyboard to use temporarily too.
Compaq Laptop... | Answered on Oct 25, 2009
LOWER THE REFRESH RATE FOR THE MONITOR.
GO INTO CONTROL PANEL, OPEN PERSONALIZATION FOLDER, OPEN DISPLAY SETTINGS,
OPEN ADVANCED SETTINGS, TROUBLESHOOTING
IF YOU NEED MORE HELP YOU CAN CONTACT ME THREW THIS SITE RODGANDYSR@GMAIL.COM FOR MORE HELP ON LINE THREW THIS SITE
ROD
Compaq Laptop... | Answered on May 12, 2009
the laptop's all use nvidia display units
email me the make and model laptop you have and i will be glad to help you with your problem
email
ruanelectronics@gmail.com
Copy-protected DVDs prohibit people from copying them, which is piracy. Copying a DVD to sell or even to give away is illegal. You can play copy-protected DVDs in a standalone DVD player or in your computer's DVD drive, as long as your computer's software is up to date. These DVDs will play the same as DVDs that are not copy protected
Press the "Eject" button on your DVD player to open the DVD tray. Set the DVD into the tray, and push the "Eject" button to close the tray. Press the "Play" button on your DVD player, and the DVD will play. b> On a DVD Drive on a Computer Press the "Eject" button on your DVD drive to eject the DVD tray. Set the DVD into the DVD drive, and push the tray in to close it. Click the "Start" tab on your computer's home screen to open the "Start" menu. Click on "My Computer" to open it. Click on the DVD drive to open the DVD. Click on "Autoplay" to play the DVD.
Compaq Computers... | Answered 13 hours ago
A dvd burner will burn anything you tell it to burn, the things is you need certain programs to see what the extension was that you burnt.
EX- if you burn a DIVX file, windows media player won't see it, but it will see a WMP file.
The most important thing is the burning software, makes it easy to burn boot, ISO files, video.
But like I said, a DVD burner will burn anything you tell it to burn.
Compaq Computers... | Answered on May 08, 2019
Firstly enter the bios screen and set your boot device from HD to USB. Insert your bootable USB drive and start the machine.
Compaq Computers... | Answered on Apr 23, 2019
Compaq Laptop Keyboard for HP Pavilion DV9000 - DV9700 Logo
20 questions posted
Top Compaq Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Compaq Computers & Internet
Most Popular Question
computers screen pure black even thought
  • Computers & Internet
