20 Most Recent
Acer Monitor Lcd 19in Al1923 0.29mm 1280x1024 Tco03 - ACER - ET.L660B.045 19 inch LCD Monitor Questions & Answers
My Acer TCO03- power button is just blinking but no picture display
Blow hot air into the back with a hair dryer before trying to start it.
(not kidding)
if that works, one of the capacitors on the power board went bad.
even if that does NOT work, one of the capacitors on the power board went bad.
It is ALWAYS one of the capacitors on the power supply gone bad.
Being unplugged for a few weeks - as you stated - drained it of "juice", and it just cr*pped out. It was going to fail soon, in any event.
Fixing it can cost you less than a dollar, if you Google for information.
Best of luck!
Blacks out within seconds of being on the screen
Your monitor has problems with instability in the circuits,This causes error voltages to appear in the feedback circuits and the unit goes into protection mode to protect itself from more damage If you are still under warranty take the unit to a service center for repair. If you are out of warranty, Then you have the choice of fixing it your self, but you must research the problem and have the technical know how to open the monitor and check the circuit boards for the problem. This also requires a certain amount of test equipment. A digital Multimeter and tools to open the case. Plastic pry bars use for furniture work well, or a plastic putty knife to unlock the inside latching around the case.You will also need screwdrivers and soldering iron and a solder ****** or solder wick to remove solder. You need to do this to remove components from the boards to test them. Most likely suspects are capacitors or diodes in the power supply or in the control board. You may need to check transistors and transformers to find more serious problems. There could be a bad IC in one of the regulator or signal circuits. AsYou can see this is not a easy task for a person will little experience and test equipment to check out the problems. You might have a friend who can help you with this who has the experience and tools . If you find you cannot solve these problems, you can either buy a new monitor or take yours to a repair shop for repairs. Hope this helps you out with your problems.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
Acer aspire acc 603g uw30 turns on but turns back off. Help
This issue could be caused by several factors, including:
- Overheating - check if the laptop's fan is working and if the vents are clear of dust and debris.
- Low battery - if the laptop is not plugged in, try charging it.
- Corrupted software - try performing a hard reset on the laptop or booting into safe mode and running a virus scan.
- Hardware failure - if none of the above solutions work, the problem could be a hardware failure such as a failing battery or a damaged power supply. Contact Acer Support for further assistance.
