20 Most Recent Dell 3130cn Color Laser Printer Questions & Answers
Tip
How to solve Error ' Load Tray 1, 024-910 ?
Although this error coming from cause of size sensor, but i found and solve it from making smooth Registration Clutch.
Registration Clutch must run easy as other clutches are placed behind to registration clutch. it must not roll out the shaft when we roll manually.
on Mar 30, 2016 | Dell 3130cn Color Laser Printer
Tip
How To Remove 077-100 Error in Dell 3130cn Printer?
This is right that error 077-100 error is belong to Registration and or Exit sensor.
But if the yellow toner cartridge doesn't run so there will jamming the paper and the printer shows the error (077-100).
Actually i solve the issue after three days when i guessed and checked the yellow toner cartridge it was tighter than others.
So i replaced the yellow toner cartridge and solved the issue.
on Mar 29, 2016 | Dell 3130cn Color Laser Printer
If you are seeing any or all of these error codes on the Dell 3130cn Laser Pinter that there is a Firmware Update to address this issue. However, the firmware cannot be applied when there is an error present, so first try reseating all toners. You may need to repeat this several times before errors are cleared. Once error-free, download the Firmware from the Dell Support website and apply.
Reset the Cyan toner properly.
Follow
TapeOn a cart... Cart Error 093-919, 093-920, 093-921, 093-922 on a Dell Color Laser Printer 3110cn 3115cn 3130cn tape POST Laser Printer 3110cn 3115cn 3130cn
  1. Verify all packaging has been removed from the printer cartridge. This includes any tape or red handles. Also verify the toner cartridge is properly installed.
  2. Remove the toner cartridge and clean the toner housing of any excess toner with a clean dry cloth. Reseat the toner cartridge when finished cleaning.
  3. Check that all toners are Dell branded and not refills. Take note of all PPIDs (Serial Numbers). Check that all toners are for the correct model
    • If any toners are non Dell, swap with another toner
  4. Run diagnostics on the toner cartridge sensor.
    1. Power off the printer.
    2. Hold down the and buttons on the printer and power the printer on.
    3. Release your fingers from the keys when the message Diagnosing... appears.
      Customer Mode and ESS Diag display.
    4. Press the button until IOT Diag appears and press the button.
      On the LCD, Digital Input appears.
    5. Press the button until Digital Input appears and press the button.
    6. Press the or button until DI-8 for (yellow) DI-9 for (Magenta) DI-b for (Cyan) and DI-a for (Black) appears and press the button twice. It is only necessary to run the diagnostic on the toner cartridge to which the error applies
    7. Open the front cover. (Figure 1)
      Figure 1 - Open the Front Cover
    8. Remove and replace the toner cartridge. Every time the toner cartridge is reseated, the counter on the Operator Panel will increase by 1.
      • If the diagnostic does not increase by 1 then replace the toner cartridge.
      • If the diagnostic does increase by 1 and the error persists, Please contact Dell Technical Support for further advice.
Knowledge Base
Dell 3130cn... | Answered on Mar 05, 2016
in your paper tray can you check please if it is set correctly, also the paper that your using does it curl on exit? this could indicate damp or humid paper
Dell 3130cn... | Answered on Feb 14, 2016
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Dell 3130cn... | Answered on Sep 24, 2015
hi there
thats an expensive printer -- you desrev some answers, direct from their techsupport
The printer is new, you should get in contact with Dell, as its under warranty
if dell has inconvenienced you that much, i would ask for free toner cartridge or something of value to compensate : they usally do that for customers
review the firmware information for the printer , see if you have the latest version, if not go to this link to download
http://support.us.dell.com/support/downloads/download.aspx?c=ca&cs=cabsdt1&l=en&s=bsd&releaseid=R269308&formatcnt=0&libid=0&typeid=-1&dateid=-1&formatid=-1&source=-1&fileid=396303
may this serve you well !
Those little squiggle marks are caused by a component in the toner cartridge. Some time ago the manufacturers changed a plain full width foam roller, to one that has a spiral of foam along its length. It was a means of shaving a few coppers off the manufacturing cost. It happens when the cartridge is a bit old (even though it might not have been used - some materials age) There are two solutions to this.
1. Change the cartridge.
2. Find an old cartridge with the old full width foam roller, and swap that (together with its supports) into the new cartridge. Works every time.
Dell 3130cn... | Answered on May 01, 2015
Uninstall your software reboot the computer then reinstall the software. Sounds like the spooler is corrupted.
Terry
Dell 3130cn... | Answered on Mar 03, 2015
Hello everybody! i resolved this kind of problems by removing the small piece of paperwas jammed in, my advice is just check inside printer because I did it for 10 or may be 15 times and fixed it on 16 times )))
Dell 3130cn... | Answered on Jan 13, 2015
I can only assume you mean 094-422 error. I do not think there is an error code 091-422. Anyway here is what error code 094-422 means:
The transfer belt unit must be replaced every 100,000 pages, usually along with the fuser and feed rollers as part of a maintenance kit.
The error code 094-422 indicates the belt has reached 75,000 page and as a result has 25% life or less remaining.
The belt does not need to be replaced immediately and can continue to be used until end of life is reached.
Dell 3130cn... | Answered on Aug 20, 2014
Download the following manual and check pages 1-293 through 1-308. The main problems with line on the page are do to (1) bad toner cartridge, (2) bad transfer belt and (3) bad fuser. If you want a more detailed explanation on how to get ride of lines let me know.
http://www.refurbisheddellprinters.com/content/manuals/service/Dell%203130cn%20Full%20Manual.pdf
Dell 3130cn... | Answered on Aug 16, 2014
Go here: http://en.community.dell.com/support-forums/peripherals/f/3528/t/19494398.aspx
Dell 3130cn... | Answered on Jul 09, 2014
Dell 3130cn Color Laser Printer Logo
164 questions posted
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
screen saying replace k tape
  • Office Equipment & Supplies
