20 Most Recent Dell 2135cn All-In-One Laser Printer Questions & Answers
ROKU 1 XDJ0A113014862
ROKU 2 LT 16A182002191
ROKU 2 LT #2 16A19K025194
ROKU HD 18D2CP067635
Roku TV 2N002P050587 2WE012050587
ROKU HDMI STICK 2L64AW112785
all running wireless on a actiontec C2000A
For more help visit cbrtechsolutions
Dell 2135cn... | Answered on Jul 02, 2018
yes
get a can of compressed air from an electronics shop or google it to find a seller.
Then pull out toner cartridges and blow any loose toner out of printer - preferably outside the building. Check if any loose toner on toner cartridges as well. Check rollers for paper are toner free also.
Dell 2135cn... | Answered on Jun 05, 2018
ever thought of setting up the fax section of the computer
all you have to do is scan to the folder the fax the same as sending an e-mail
Dell 2135cn... | Answered on Sep 10, 2017
You need a wireless access point. This explains how it works.
What Is Wireless Access Point Howcast
Dell 2135cn... | Answered on Feb 08, 2017
Yes. Dell has made available both 32 bit and 64 bit Windows 10 drivers for this device so it should work on you Sony. This printer is network enable but it is wired, not wireless so you will have to connect it to your network with a ethernet cable.
Here are the drivers:
Support for Dell 2135cn Color Laser Printer Change product
Here is the manual:
http://downloads.dell.com/manuals/all-products/esuprt_printers_main/esuprt_printers/dell-2135cn_user%27s%20guide_en-us.pdf
If the power button is lit then there is power going to the printer. However, if there is no display coming on then there could be an issue with the system board on the printer.
We can try doing a manual reset to see if that helps.
Unplug the power cable from the printer.
Press and hold Start button(Green button) and Cancel button(Red cross) while you plug the power cable back in.
Let go of these buttons once the power light is lit and check if the display comes back on.
If the issue remains the same then the printer needs to be replaced. Please let us know if this helped. Thank you.
Dell 2135cn... | Answered on Dec 27, 2016
Dell 2135cn All-In-One Laser Printer paper jam
Dell 2135cn... | Answered on Jul 02, 2016
Knowledge Base
(Click the above link for your answer & resolution)
Dell 2135cn... | Answered on Feb 02, 2015
Did you check to see if all ink cartridges were full. or the print heads were good. I am not familiar with this printer however look up the manual on line to see if they have instructions how to clean the print heads. It is important that you follow instructions as ignoring them could cause damage especially to print heads.
Dell 2135cn... | Answered on Jan 17, 2015
The way I resolved the issue is to go to the Printer... literally walk to it (not via Windows or a Driver), Select Menu button on printer->Setup->Admin->Maintenance->Clean Developer. This will clean each toner cartridge or PHD unit, or to stir the toner in a new toner cartridge. Then it started printing solid black again.
It took me hours to resolve this but I hope it helps someone else and spares them the pain.
Dell 2135cn... | Answered on Dec 20, 2014
Pull out all the toners and look at the drive gear on the problem color. They are located on the right side where the toners slide into the printer. Odds are you have a bad gear in the dispenser assembly. Can't just buy the replacement gear anywhere you have to buy the whole unit and that runs $250.00 to $300
Dell 2135cn... | Answered on Oct 21, 2014
Try this, it may be a large print job held in memory.
Press 80-0-1327 to clear the message, cancel the current print job, and conduct the next print job, if any. · Press Cancel to cancel the print job.· Press Menu to open Stored Print and delete the holding job. · To avoid this error in the future, do the following:· Delete unnecessary fonts, macros, and other data in printer memory. · Install additional printer memory.
Dell 2135cn... | Answered on Oct 02, 2014
The fuser heats the toner on the paper fixing the image so that it does not smear. It is not used in the scanning process, only printing and copying.
Dell 2135cn... | Answered on Jul 15, 2014
I would check the plastic gears on the paper transport rollers. These gears can break when a paper jam suddenly stops the rollers.
Automatic document feeder
At the top of the device you can place paper to be scanned, and when you tell it to scan it gets "sucked in" to the printer? That is the ADF. You should be able to open it up, maybe with a switch, some need force.
Dell 2135cn... | Answered on Jul 14, 2014
Dell 2135cn All-In-One Laser Printer Logo
220 questions posted
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
2135cn installed new black cartridge
  • Office Equipment & Supplies
