20 Most Recent
Brother MFC-990CW COLOR INK-JET MFC Ink Jet Printer Questions & Answers
GERMAN TO ENGLISH ON MFC
Hello, you can try this simple steps configure your language in any language you want; english, german or japanese or even more! And this is the steps, kindly follow it thoroughly to changed it with ease;
1. Open your phone.
2. Tap Menu.
3. Tap Configure or Settings. (a wrench icon)
4. Tap Phone. (a phone icon)
5. Tap Language Settings.
6. Tap Phone Language.
7. Tap the language you want.
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :
Brother Printer Support
7/31/2021 9:54:59 AM •
Brother...
Answered
on Jul 31, 2021
MFC-J6510DW
check cables, ink, and if computer reconize's it.
5/14/2012 9:54:09 AM •
Brother...
Answered
on May 14, 2012
My problem is that my
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts. Sometimes the power supply unit must be checked as a poor SMPS unit can deliver low voltage and cause issues to the printer function. Check all the leads and connections of the mother board , the tags to the ink cartridge. Also check the mechanical settings of the ink cartridge , if jammed or tight remove motor and manually free the drive before it is set back.
Thank you for using Fixya
9/17/2011 6:25:15 AM •
Brother...
Answered
on Sep 17, 2011
I replaced the black ink cartridge, Innobella,
i HAVE A lc61 SERIES BROTHER INNOBELLA AND I AM NOT ABLE TO PRINT. wHEN I TEST THE PRINTING I GET ALL COLORS BUT BLACK ON THE TRIAL DEMO I TRIED CLEANING BUT IT STILL DOES NOT WORK WHAT CAN I DO???
2/18/2011 5:23:52 PM •
Brother...
Answered
on Feb 18, 2011
Inks are full. Printing has
hi!
go to ink management and select clean head for all colours
it will take 1 to 4 min
and your printer will work ok
12/16/2010 4:19:02 PM •
Brother...
Answered
on Dec 16, 2010
Ran low on inks on
me too. Brother tech said bad printer head. cost of replacement (only when bad after one year and 3 month) the same value as a new printer.
so, I use it as scanner and telephone. but still not using the printer it comsume all the ink, so it asks you to put new ink in the printer..... waste of $$$$
Will trough it to the garbage!
12/14/2010 2:53:22 PM •
Brother...
Answered
on Dec 14, 2010
Black ink does not work
A, Did u use a refilled one or a new one
B, Did u check that the black cartrige is touching the plate
C, Did u check that after putting in the cartrige the lock is put on
11/14/2010 7:31:20 AM •
Brother...
Answered
on Nov 14, 2010
