Home | Cfm | Air Conditioners
Cfm 20AC6034 Portable Air Conditioner
Problems with Cfm 20AC6034 Portable Air Conditioner?
Ask our Experts
Tell us why
Share your Experience
Do you recommend the
Problems
& Solutions
Manuals
& Guides
Repair
Service
Top
Experts
Warranty
& Spec
Troubleshooting and Support
Solved Problems for Cfm 20AC6034 Portable Air Conditioner RSS Feed
View More Results for Cfm 20AC6034 Portable Air Conditioner
Find a Manual
Cfm 20AC6034 Portable Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
Replace the unit? or Replace the compressor? Split AC or Heat Pump
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part... written by farfield
Relay Wiring tips and tricks Simple circut. What to look/lookout for
Typically if you want a circuit completed when energized you use C (Common) and NO (normally open). This means that the contact will close when... written by farfield
Don't jump to "Its low on charge; because its froze up"
A low charge diagnosis for instance can be miss read if the evaporator is iced up or has any ice in or on it. A sticking thermostat, relay, or... written by farfield
How to Trouble shoot Low Voltage Controls on AC-Heat
What I have always been told is if your 24 volt side burns out check the high volt side if the hi volt side burns out check the low volt side. A... written by farfield
COMPRESSOR check outs semplified.
If your wondering how to check out your refrigeration compressor; Modern Compressors have two operations that have to work together just to run.... written by farfield
Air Filter changing - easey and often
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date... written by farfield
AC DRAINAGE PIPING REQUIREMENT
Slide 71 .O {color:black; font-size:149%;} a:link {color:#CCCCFF !important;} a:active {color:#3333CC... written by bobotfel
HOW TO CHECK A GOOD REMOTE CONTROL
HOW TO CHECK A GOOD REMOTE CONTROL Using Camera or Cellphone Camera, use the camera as your eye point the remote control transmitter to the camera and... written by bobotfel
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for 20AC6034 Portable Air Conditioner
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Find an Expert
Meet our 2574 Air Conditioner Experts
dmftrucker
Rank: GuruGuru
Rating:  88%, 344 votes
Solutions:  1494 (542 Votes in the last 30 days)
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
milten1
#2: milten1
Rank: GuruGuru
Rating:  91%, 449 votes
Solutions:  1303 (508 Votes in the last 30 days)
Experience: 15 years field experience and 5 years navy training
57 varieties
Rank: GuruGuru
Rating:  88%, 429 votes
Solutions:  1364 (342 Votes in the last 30 days)
Experience: I have been solving problems and fixing things for over 30 years!
roniecon
#4: roniecon
Rank: GuruGuru
Rating:  88%, 555 votes
Solutions:  1872 (329 Votes in the last 30 days)
Experience: A S E certified /35 years experience
techbuster
Rank: GuruGuru
Rating:  90%, 441 votes
Solutions:  990 (328 Votes in the last 30 days)
localwonder
Rank: GuruGuru
Rating:  92%, 2686 votes
Solutions:  4740 (318 Votes in the last 30 days)
Experience: I have yrs of experience dealing with many situations.
projdoc
#7: projdoc
Rank: GuruGuru
Rating:  94%, 440 votes
Solutions:  900 (243 Votes in the last 30 days)
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
justaskjoe
Rank: GuruGuru
Rating:  85%, 1881 votes
Solutions:  3545 (239 Votes in the last 30 days)
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
buffalonyman
Rank: GuruGuru
Rating:  85%, 680 votes
Solutions:  1741 (230 Votes in the last 30 days)
Experience: Licensed Master Electrician for 25 years, Plumbing, HVAC, Custom Build Computers, Automotive
SRF518
#10: SRF518
Rank: GuruGuru
Air Conditioners ExpertExpert
Rating:  88%, 60 votes
Solutions:  224 (224 Votes in the last 30 days)
Experience: Licensed Master Electrician for 35 years. Have a vast knowledge of mechanical items.
Find a Warranty
Specifications for Cfm 20AC6034 Portable Air Conditioner
Key Features
Remote Control
Without Remote Control
Cooling Capacity
60000 BTU/hr
Energy Efficiency Rating
10.2 EER
AC Type
Portable
Other Features
Air Flow
3000 CFM
ENERGY STAR
Without ENERGY STAR®
Cooling Operating Range
55 - 105
Dimensions
Depth
39 in.
Height
53 in.
Width
28 in.
Electrical Requirements
Voltage
414 / 506
Cooling Ampacity
11.4
Cooling Watts
5900
Product MPN
MPN
20AC6034
Describe your problem:
Sponsored Links
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
