20 Most Recent
X2Gen MG19VT 19" LCD Monitor Questions & Answers
My monitor keeps burning up the power adapter,why?
how many power adapter leads have been burnt its getting to hot quite possible it has a short but if its has burnt more than oneclean your computer of dustcheck all connections from motherboard to hard drive make sure they have dust free secure connections
Budmrtn, Thanks for your help so far on my "out of
Go back to boot up menu but dont restart the computer yet. go to start>right click computer>properties>device manager>under display adapter select your video card right click it and uninstall it.
after uninstalling restart the system; reinstall the video driver for your graphics card.thanks
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
Lost manual
I suggest you follow the link below to search for the manual of your device, the link contain virtually all the manuals of all device.
manualsonline.com
Type the above link on your web browser to search and download the manual of your device.
Take care.
Buzz coming from speakers
Buzzing is usually caused by bad audio ground connection. Try insert and reinsert the audio cable first. It can also be the sound card. Try using the MP3 player as the sound source feeding the monitor, if it still bad then it can be problem in the DC filter caps in the power supply, or bad sound IC in the audio board inside the monitor. Please post back what you find.
http://s807.photobucket.com/home/budm/allalbums
Power turns off and on fr abour 5 minutes before finally staying
This is a classic symptom of a failing power supply. After 2-3 years of use many LCD power supplies will start fail because of parts called capacitors that start dying due to the heat buildup in the monitor case. If you can solder then you should be able to do the repair yourself. Check out this page on our web site;
http://www.ccl-la.com/blog/index.php/capacitors/ This article explains what capacitor are, how they fail and what you will need to get for the replacement parts. The parts can be ordered from many places on the internet, we stock they too. If you don't want to do the repair yourself we do offer a repair service, that info can be found here:
http://www.ccl-la.com/blog/index.php/service-request-form/ I hope this helps you, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
