20 Most Recent
HP Compaq Presario V6000T 15.4" Notebook PC Laptop Questions & Answers
What to go in to find the airplane mode
Try FN + a button that looks like signal lines, the WiFi button basically, it should turn off aeroplane mode, I assume you're using Windows 8. You can also turn it off by pressing Windows Key + C at the same time to bring up the charms menu (the menu that appears on the right) press settings, click on the wireless section, turn off aeroplane mode at the top.
3/9/2014 5:02:57 PM •
HP Compaq...
Answered
on Mar 09, 2014
Airplane mode
I presume you have a Windows 8 operating system.
1. Press [Windows Key] + Q key.
2. Type "airplane" in the Search box,
3. Click the "Settings" (it is found in here)
4. The "Turn Airplane mode on or off" note will be displayed; click it.
5. PC Settings screen with airplane mode slider will be displayed,
6. Slide the Airplane mode slider to off.
3/9/2014 5:45:33 AM •
HP Compaq...
Answered
on Mar 09, 2014
My compaq v6000 will not power on. Power on light
this can be a numerous amount of things
your battery could be messed up if you have taken the computer appart your fan might be unplugged or something might be miss seated check for beeps if you hear beeps then its something that isnt placed right inside your computer and you need to check it out
12/24/2012 3:33:05 PM •
HP Compaq...
Answered
on Dec 24, 2012
When i start my pc, os not found. the recent OS is
use windows vista home premium cd
boot using windows vista cd
after setup run chose repair your computer this option will detect your previous windows
it will direct you to system recovery option and this process wil automaticly repair and restore you system, wait and follow the instruction until finish
i hope this helpful
thank you for using fixya
2/7/2011 5:20:09 AM •
HP Compaq...
Answered
on Feb 07, 2011
Hi I have just purchased a compaq d6000 it didn't
merrilynquir
In regards to the battery not holding a charge most likely the battery is out of life. Normally notebook batteries will last 2-3 years with normal use but if the notebook was used alot then the average is 1.5 to 2 years. Note I have to replace my batteries about every 2 years.
I also found this if you go to the below link and look under Utility -Tools there is a battery test program.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&os=228&product=3177516#
As for your computer running slow you most likely need to reinstall Windows on your computer. If you did not get any of the disks with the computer you might check to see if the restore partition is still there normally if you open my computer it will be a 10gb partition. If it is there then you should be able to do a restore on the system to take it back to factory settings. Note normally the recovery mode can be accessed by pressing F12 when you first boot the computer.
If you need to order replacement restore disk you can do that from the link above and selecting the Recovery Media section.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
9/9/2010 7:25:23 AM •
HP Compaq...
Answered
on Sep 09, 2010
Blank screen
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
4/6/2010 2:27:24 PM •
HP Compaq...
Answered
on Apr 06, 2010
unplug the battery and charger hold your power button pressed for 1min then plug it back in and try to boot ,if no joy and stil under warrenty contact reseller ;)
3/11/2010 11:28:54 PM •
HP Compaq...
Answered
on Mar 11, 2010
Is the microphone available on compaq presario
Any "modern" laptop will either have a built-in microphone,
or it will have a small "microphone-in" socket where any separately-purchased microphone can be connected. Look for a small hole with a PINK ring around the hole.
1/2/2010 2:51:55 PM •
HP Compaq...
Answered
on Jan 02, 2010
When I turn my V6000 on, I have power lights and
Sorry to hear about your V6000 problems.
If this problem has just started and all was OK before this happened.!
1. Remove all media from drives.
2. Remove battery and A/C power input.
3. Flip unit over and remove the memory.
4. Disconnect the CMOS battery.
5. Remove the Hard Drive.
6. Flip unit over and Press the Start Button for 30 seconds.
7. Flip unit over again and re-install the Hard Drive, Memory and last, the CMOS battery.
Note ...
8. Reconnect the unit to the A/C input supply voltage.
Leave the battery out for NOW !.
Flip unit and try to start with the Touch Pad Led's. This should bring up Quick Play.
If your unit starts and you here several beeps,
Don’t worry, !! You should be able to access the BIOS screen. You can reset your date and time.
If you are still not able to start unit, drop me a email and I will try some other ideas.
Hope this works for you. !!
Try it, It may work !!
John Ray
[email protected]
Readers please rate your information, even if you disagree, it shows the technician, you care enough to respond.
Thanks.
7/9/2009 4:34:12 AM •
HP Compaq...
Answered
on Jul 09, 2009
Disappearing DVD driver
Use device manager to remove the dvd/cd unit, and then reboot the computer. Vista will locate the unit and install the driver.
It is possible that the dvd/cd unit has failed and requires repair or replacement
7/5/2009 2:17:18 PM •
HP Compaq...
Answered
on Jul 05, 2009
Sound drivers r not working,how to install it.
Save the file in a folder, could it be in your desktop so you can find it quick, then go to the .ZIP file, Right Click on it, and then "Extract Here"... Then, you must find the "setup.exe", run it and follw instructions... and that's it. Any issue, please ask
Don't forget to rate my comment... Thanks!... (=
7/5/2009 7:21:08 AM •
HP Compaq...
Answered
on Jul 05, 2009
Driver problem
Some drivers doesnt works with xp sp3, try uninstalling xp sp3 from add and remove programmes.
6/17/2009 11:33:38 AM •
HP Compaq...
Answered
on Jun 17, 2009
