20 Most Recent Dell PowerEdge T300 Server Questions & Answers
Use GOOGLE and SEARCH for:
First Search for:
Dell PowerEdge T300 Server list of Error codes
(12,600 hits)
then search for:
Dell PowerEdge T300 Server Error code "2900-0325"
(You will find 40 'hits')
Anthony
Dell PowerEdge... | Answered on Dec 15, 2017
Windows 2000 is not supported on this machine. The closest you could get is using a hypervisor XenServer or VMWare ESXi and then installing Windows 2000 on a virtual machine.
Dell PowerEdge... | Answered on Sep 26, 2016
Sounds like you're running into a security limitation. Firewall, etc... Corporate software is perhaps blocking the request for that site.
Honestly? I'm not really clear on the situation as your question is poorly constructed.
I'm guessing this is too old to be an issue at this point, however.
Dell PowerEdge... | Answered on Jun 13, 2015
He shows you how to open the server then you should see the memory.
Dell PowerEdge... | Answered on Oct 14, 2014
The e1410 is an error that is reporting an interruption to the CPU processes. It isn't identifying an issue with the processor specifically, it is just saying its processes were interrupted. Normally when you see the E1410 you will see another error listed with it in the hardware log. Do you see any other errors in the log? Also, what is the BIOS and Drac versions at currently? I ask because the server being very out of date can cause issues like this as well.
Let me know what you see.
Dell PowerEdge... | Answered on Sep 04, 2014
Your corporate Firewall is denying access. I don't know what this site is or does, but you can put in a request to allow access with your IT guy or use it at home.
Dell PowerEdge... | Answered on Jan 22, 2014
ENGLISH PLEASE.
Dell PowerEdge... | Answered on Aug 13, 2013
It's one of two things, you have something loose and your fan is rubbing on rubber in there, you just need to take it apart use some air duster and dust it out and see if anything is rubbing or second option is that your power supply has gone out completely and will need to be replaced.
Dell PowerEdge... | Answered on Jul 24, 2013
Verify size and type off memory. Also the slots used are a variable. There should be DIMM configuration table on the removable panel or better yet look for the manual.
Dell PowerEdge... | Answered on Mar 28, 2013
You can try first enabling it from device manager if still not being enable you will need to enable it from your BIOS.
Dell PowerEdge... | Answered on Mar 18, 2013
First, go to Dell's website and update all the firmware and install the latest version of Dell Server Administrator. DSA has logs information not logged by Windows. Next, take it outside and blast the fans with compressed air, make sure all components and cables are properly seated in their slots/sockets, turn it on with the cover off and make sure all the fans are spinning. Many servers will increase the fan speed if they detect the cover is off so this is another possible cause to the problem.
Finally, Dell servers have lifetime support, this number should work: (800) 945-3355
BTW: A temporary workaround might be to use a network controlled outlet that you can remotely turn off and on. Your UPS might be able to turn outlets on and off or you could get a stand alone network controlled outlet. Some can actually ping the device and turn power off and on again if it stops replying to pings. (E.g. IP Power EV-9255 IP http://www.newegg.com/Product/Product.aspx?Item=9SIA1470N64280)
Dell PowerEdge... | Answered on Mar 06, 2013
BIOS must see the optical drive. Re-seat / attach drive if it does not. The other option is to use another drive.
Dell PowerEdge... | Answered on Jan 14, 2013
Disassemble Components an Clean the System with Air blower,
& Assemble Components Check it
Dell PowerEdge... | Answered on Dec 20, 2012
I will assume you are trying to connect to another desktop from the server... You may need to setup share properties on the desktop to access it from the network. If you are using VM software on the server and having this issue, you need to reconfigure the VM setting for your user access level.
Good Luck
C2S
Dell PowerEdge... | Answered on Dec 24, 2011
If your Dell server cam with the Windows Server 2003 software, you should be able to order a replacement cd. Go to http://www.dell.com/support If the software was not packaged with the server, you will have to buy it at http://www.microsoft.com/sales
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Dell PowerEdge... | Answered on Jun 23, 2011
Dell PowerEdge T300 Server   Logo
Popular Tags
38 questions posted
Clive
Clive
Alun Cox
View Most Popular
PowerEdge Dell
  • PowerEdge Dell
Most Popular Question
poweredge t300 server am having issues
  • Computers & Internet
