Troubleshooting & Support
Problems & Solutions
i have a vizio vu42l
There not need not be burn marks when components are shorted. And yes I do think its definitely a case of short in the power supply. I am...
VU42LFHDTV10A Vizio will not power up. I am
You should check the fuse in the power supply module, that will be the first thing. You can look for new power supply on EBAY at such place...
vizio 42" lcd powers up with sound only - no...
It sounds to me that the unit has a faulty inverter board which could be due to an overheated/bulged capacitor. I would send in a claim on...
I have a large spot
Not possible.Tv have damages to it LCD screen panel by an object or a person have causes by forced or putting pressure to the tv LCD screen...
Vizio VU412L 42" made a
The pop has been generated by the explosion (literally) of an capacitor from the power board of the tv. When that happened the power source...
the tv will not power up. I have power to the
Any time a TV has no power is your power supply that needs to be replace. Check for blownen caps. Thank you
i have a vizio lcd
Here is a link to the Online User's Manual for your TV in case you don't have one already:...
Intermittently my Vizio model e370va volume will
I was having the same issue. I found this on Fixya and it seems to have worked. Okay I just called and found this out. I have the 32 inch...
Sound went. No popping or arcing. Picture still
had a very similar situation with my Phillips 42 in. LCD TV. Here was my Problem. The Power Supply Board. I opened it up( Warranty was...
3year old Vizio made a
Hi Thanks for using FixYa. You are right the pop noise that you hear is from a component (usually capacitor) going bad on the...
i have a vizio 42 in lcd p .will the lcd fit in...
The screen can cost as much as a new TV, you can try contacting www.shopjimmy.com to see what he has in stock....
3 y/o Visio VU42L with no pix or sound
well,mike seems youve done everything to your TV and nothing happen..Try to reset the system of your TV.On the main board there is a small...
vizio 42 lcd gets large dark spot. it will go away
HI... It's probably a loose flex cable inside. Look on the web and find someone near you Have a service tech check it inside for you
black no picture but sound.with the tv cable.
This problem is usually caused by a failed t-con board or a dead backlight inverter. Follow these simple diagnostic procedures to figure...
I have a 42
Probably not - tv repair is very expensive now.
Unsolved Problems
after 1 hr the sreen has lines going across it on...
something is over heating but I need values to test parts
I have a Vizio 42
I have a Vizio 42 inch tv. I too lost the screws to the stand and now need to replace them. I have model number VW42FLHD...
i just replaced the power
i just replaced the power board on my vizio VU42L FHDTV 10A and i have the same problem.. after a few moments the...
I moved and lost my
I moved and lost my screws for my VIZIO TV Stand. ModelNo. VIZIO VW37L HDTV10A
I HAVE VIZIO TV THAT
I HAVE VIZIO TV THAT HAS BROWN SPOTS ON SCREEN CN IT BE FIXED?
picture & sound on
picture & sound on screen flashes constantly
My 42 in vizio appears
My 42 in vizio appears to come on but does nothing after that. It wil not power down unless it is unplugged. The...
Upload a manual for Vizio VU42L 42 in. LCD TV
Specifications
TopKey Features
Full Product Name:Vizio VU42L 42 in. LCD TV
Weight:46 lb.
Screen Size:42 inch
Contrast Ratio:1,500:1
Flat Panel Type:LCD TV
Display Resolution:1920 x 1080 pixels
HDCP Support:With HDCP Support
LCD Response Time:8 ms
Technical Features
Picture in Picture:With PIP
Parental Control:V-Chip
Dimensions
Depth:3.9 in.
Height:27.3 in.
Width:40.5 in.
Warranty
Overall Warranty:1 Year
Display Capabilities
Built-in Tuner:ATSC
Broadcast Format Supported:1080p (HDTV)
Broadcast Format Displayed:1080p (HDTV)
Interpolated Aspect Ratio:14:9 Enhanced
Native Aspect Ratio:16:9
Remote Control
Remote Control:Standard
Audio Features
Audio Type:Virtual Surround
Image Quality
Comb Filter:3DYC / 3D Digital
Pixel Pitch:0.485 mm
Brightness:500 cd/m²
Output Color:16.77 million colors
Viewing Angle:178
Adjustable Color Temperature:With Adjustable Color Temperature
Speakers
Number of Speakers:2 Speakers
Speaker Power:2 x 10 Watt
Combo Features
Playable File Formats:MPEG2
Product MPN
MPN:V49148
What's your problem?
Fix-O-Meter
10,330
10,330 people have viewed this product
- 68 people asked about this product.
- 18 people found solutions for this product.
- 1 person has added this product.
Polaroid...
Programming...
Working with...
