20 Most Recent Toshiba REGZA 37RV530 LCD TV Questions & Answers
problem vith neon tube or driver trafo for it
Toshiba REGZA... | Answered on Sep 18, 2017
Kindly switch off the TV, switch off power, and remove plug. The TV needs servicing by a qualified service technician.
Toshiba REGZA... | Answered on Aug 25, 2012
Go to your tv menu page then to preferences tab, scroll down to energy saving settings and click to open, there you will find the option to turn off the Automatic Power Down Setting.
Toshiba REGZA... | Answered on Apr 07, 2012
the backlighting in the tv might be going out. that is the first hing to look at. it might also be the liquid crystal display itself. you can look for the backlighting yourself by unscrewing the back panel from the lcd tv. and simply turning it on. you will see if one of the lights is dimmer than the other or just simply out. if you dont want to do that yourself take it to a tv shop and just have them look at it. most tv repair shops coast to coast dont charge to look at it for you. if one does go to the next. they are in just about every city. (checking it for free) hope this is helpful
Toshiba REGZA... | Answered on May 10, 2010
the manual doesn't mention anything about setting the time, so I am wondering if it comes from the cable or satellite box connected to it.
this is how it is done on another Regza model
Setting the time zone
The Time Zone setup will allow you to specify the
correct time zone for your region. This feature will
allow the TV status information to show the correct
time zone information for your viewing area.
From the SETUP menu, highlight TV Settings and
press T.
Press B or b to select Local Time Setting and press
T.
Highlight Time Zone and press C or c to set your
desired time zone.
If you want to activate the daylight saving time,
highlight Daylight Saving Time.
5
Press C or c to select On and press O.
Toshiba REGZA 46SV670U Owner Manual Setting The Auto Input Feature Setting...
your model manual
Toshiba 42HL67 42 LCD TV Service Manual
Toshiba REGZA... | Answered on Jul 24, 2017
Some people recommend trying to update the firmware via USB. Instructions here, http://hubpages.com/technology/How-to-Update-Toshiba-TV-Firmware.
If it is a model 32C120U, there is a known manufacturers defect. This issue is cause by defective main board because the main processor is not well solder to the PCB or the e-prom memory lost the software data. Some time you can try replace the eprom memory on the main board (cost of the e-prom $15) or re-solder with a hot air gun the processor but 90% of the cases you have to change the main board, the cost is around $30 you can find it in www.myshoptvs.com these guy are super. To replace the main board is easy and takes not more than 25 minutes.
This could be your board here, http://www.myshoptvs.com/marketplace/4169-toshiba-32c120u2-main-unit-461c4q51l11-431c4q51l11-vtv-l40613-m6662.html
Toshiba REGZA... | Answered on Mar 19, 2016
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Toshiba REGZA... | Answered on Mar 10, 2016
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Toshiba REGZA... | Answered on Aug 27, 2015
Toshiba REGZA... | Answered on Aug 13, 2015
-Let it play and just listen.
Good luck and enjoy
Mai
Toshiba REGZA... | Answered on Aug 05, 2015
contact foxtel as you will need a service provide approval and then they will talk you through the process.
foxtel is a pay provider and not free to air.
Toshiba REGZA... | Answered on Jul 25, 2015
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Toshiba REGZA... | Answered on Jul 20, 2015
Make sure the connections etc are all good. make sure the router is operating. You may have to turn off both TV and router and unplug from power supply for 10 or 15 mins. Plug back in and both should reset and connect.
Toshiba REGZA... | Answered on Mar 08, 2015
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Toshiba REGZA... | Answered on Feb 24, 2015
Corrupted firmware. A firmware update is necessary. Contact any experienced service technician, or the authorized service centre for Toshiba. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Toshiba REGZA... | Answered on Dec 07, 2014
Toshiba REGZA 37RV530 LCD TV Logo
10 questions posted
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
REGZA Toshiba
  • REGZA Toshiba
Most Popular Question
3 5 top bottom area left side clear brit
  • Televison & Video
