20 Most Recent Proscan 32LB30H LCD TV Questions & Answers
Charter has a web site tat list the codes. Bit hard to find the url so you might call support
Proscan 32LB30H... | Answered on Oct 21, 2015
Not so easy but try to call customer service for the brand (Proscan used to be RCA-GE-Thompson) to with the model number find the number, length, and thread type of the bolts.
Proscan 32LB30H... | Answered on May 01, 2012
grab a flash light .with the tv on and while making sure you have a signal hearing the sound.Shine flashlight at tv screen look closley.if you can see the video on screen with flashlight ..Then you have internal problem with lcd backlight inverter section or power to inverter..
Proscan 32LB30H... | Answered on Sep 22, 2011
If you can open than open your LCD tv & checked Inverter Borad it have White & red color connector may be this board is defective.
Proscan 32LB30H... | Answered on Aug 11, 2011
there is a bad ground.
the hum you are hearing is ac getting into the audio.check all the rca plugs on the set are plugged in all the way.do not run them close to a power bar either.
sometimes a second unit with it's own volume is hooked up to the tv and then the tv volume is up too high because the other box is turned down.if there is a unit hooked up,turn it's volume up ,and the volume on the tv down,otherwise the tv will amplify the residual noise.cheers,ed
Proscan 32LB30H... | Answered on Sep 07, 2010
I had the same problem and code 0178 worked for me. It isn't anywhere that the other codes are on the internet, I just found it on a message board somewhere.
Good luck and I hope this one works.
Proscan 32LB30H... | Answered on Jul 12, 2009
set up channels go to tv air then channel search blue ray change input or source
Proscan... | Answered on Apr 27, 2019
12147 or 12256. Give those a shot a let me know
Proscan... | Answered on Apr 26, 2019
go into audio settings and change
Proscan... | Answered on Apr 10, 2019
Sorry but no. The good news is that you can add extra sound to make up for it with a surround sound system- a basic/inexpensive system is all you need- u get $100 all day every day!
Proscan... | Answered on Apr 08, 2019
Return to the initial set up procedure and disable it.
Proscan... | Answered on Apr 06, 2019
Download a universal remote app on your phone
Proscan... | Answered on Mar 30, 2019
Proscan 32LB30H LCD TV Logo
20 questions posted
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Proscan Televison & Video
Most Popular Question
television recently repaired
  • Televison & Video
