20 Most Recent Hannspree HT09 28 in. LCD TV Questions & Answers
Sounds like a T'Con board fault. If you're sound in electronics, and wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Flip card, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Hannspree HT09... | Answered on Nov 01, 2013
To release V-Chip code, you have to enter its service mode. Check this link. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option. It has details about how to enter, adjust and exit service mode, to many brand TVs.
Hannspree HT09... | Answered on Jul 04, 2013
10030 for the comcast dvr remote. Code is from NEC
It sounds that the fault is with the connections that goes to panel from its T'Con board. Check all the flat cable connections. Re-seat them once.
Hannspree HT09... | Answered on Jan 12, 2013
What is the problem you faces with this TV? Provide more details please.
Hannspree HT09... | Answered on Sep 14, 2012
Use HDMI 2. This T.V. is unlikely to have replacement parts because it is not a mainstream TV. (Samsung, Panasonic, etc..) Make sure your HDMI cable is good too and your cable box or what ever other device you're using is properly connected and on.
Hannspree HT09... | Answered on Jun 19, 2011
Hello, this is a simple issue to fix!!!! follow these simple steps from our website, and that remote will be working right away!!!!! Now, to program your remote to the TV, you will want steps 6 and beyond. And all steps 1-5 are for programming the remote to the receiver. Hope this helps!!!!!!!!!!!
http://www.dishnetwork.com/SupportSection/remote-setup
Becki Barned
DISH Network Customer Service
Hannspree HT09... | Answered on Jan 16, 2011
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
Hannspree HT09... | Answered on Jan 11, 2011
Buy a learnable remote.
Hannspree HT09... | Answered on Jan 01, 2011
Check the power suply caps and backlight inverter for shorts, please read below to understand how the LCD TV works.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Hannspree HT09... | Answered on Aug 09, 2010
The cost would be prohibitive if you could even find one. Possibly one from Craigslist that is not working but good screen, otherwise throw it away or sell for parts. New ones are too cheap to try and repair that component.
Hannspree HT09... | Answered on Dec 28, 2009
Faulty Video boards If you bought it in May then rapidly get it fixed under warranty or exchange it for a better brand. Who is Hannspree? not well known and may be cheap Korean TV with no parts available
Please rate our help to keep FREE service online++++Thanks for using FIXYA
Hannspree HT09... | Answered on Sep 12, 2009
Hannspree HT09 28 in. LCD TV Logo
32 questions posted
Top Hannspree Televison & Video Experts
paul
paul
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hannspree Televison & Video
Most Popular Question
got sound but no picture lcd not even
  • Televison & Video
