20 Most Recent Philips Magnavox MWC20T6 TV Questions & Answers
Look for a setting called Aspect Ratio. It will include options like 4:3, 16:9, Zoom 1, and Zoom 2. Then click through the options to select the correct one for your program. Usually older SD programs will use either 4:3 or Zoom 1, while HD programs will be set to 16x9 for Widescreen hi-def viewing. There should be a button on your remote labelled Aspect Ratio or Picture that can toggle through these image modes.
Philips Magnavox... | Answered on Nov 26, 2014
Hi
If you have a friend that is keen on electronics, your tv set may be open and checked for a blown fuse, as a firt step of troubleshooting. This is applicable when no light in the front panel is on or blinking. If this do not work or the fuse blows again, there is a short circuit or a bad component that need to be replaced. But this task require another approach.
Please follow the instructions on dealing with high voltage parts of the tv set.
I shall be glad if this is helpful.
Sully
Philips Magnavox... | Answered on Sep 27, 2013
Try visiting the Philips website, they often have free PDF of manuals.
Philips Magnavox... | Answered on Sep 02, 2013
fuse went bad replace fuse.
Philips Magnavox... | Answered on Feb 28, 2011
Hello
It may be due to the change [high] in the screen voltage. You just open your tv and locate the screen control. You cn see it attached with the LOT [Line Output Transformer]. There are two controls integrated to it and are adjustable. Out of which, one is for facus adjustment, and the other is for screen adjustment. Usually the upper one is meant for focus adjust, and the lower one for screen adjustment, and there will be visible markings near it about which is it meant for. Just turn it counterclokwise a little, say very little, while the tv is on and there is screen on it, whether it is blue back or grains. More turn counterclockwise will make the picture in your tv get smeared. A little must be done.
Check this and see. Ok
Philips Magnavox... | Answered on Nov 19, 2010
Frist of all the tv is made by Funai the next thing is it is very hard to get parts from Funai at least it has been for me they tell me anywhere from 2 months to a year on parts. Now if the set is trying to load a tape without a tape being put in then shuting off you have a bad diode on the main board.Part is marked (D1224 on main board which it is called (LED) the Funai part number is (QPQS1R563ST) Need to replace this LED per Funai tec i have done this on a few of these models this problem stands true for 20 inch 24 inch and probley any others that are made by Funai that would have this kind of problem. The led that im talking about is under the VCR chasie in the center of the board and is clear glass looking. It has to be put inone way for it to work you have to unsolder it from the board. If you are not able to do this then it would need to go to a repair shop to be done. The shop may or may not know what is wrong so you could tell them, let them know that this is per Funai tec fix for this problem also give them the part number and hope that it does not upset them some shops would be ok with it and others would not.
Philips Magnavox... | Answered on Apr 21, 2009
reepende a donde vivas si vives en mexico las venden en mercado libre si vives en otro pais em EBAY o en tiendas de electronica y en tu localidad en un desguesadero de electronica si eres usuario mejor lleva tu pantalla con un especialista,y si eres tecnico consigelas en donde ya mencione.
Philips... | Answered on Sep 08, 2019
Applicable codes will be found in a compatible remote control.
Philips... | Answered on Aug 29, 2019
Hi Anonymous, search Google, LCD Panel for Philips TV 55PUT6233 / 56
Keep in mind that replacing the panel has its risks
Good luck in the search
Regards Franco Dosil
Hola Anonymous, busca en Google, Panel LCD para TV Philips 55PUT6233/56
Ten en cuenta que reemplazar el panel tiene sus riesgos
Suerte en la busqueda
Saludos Franco Dosil
Philips... | Answered on Aug 24, 2019
  • Make sure that all words are spelled correctly.
  • Try different keywords.
  • Try more general keywords.
  • Try fewer keywords.
Philips... | Answered on Aug 22, 2019
Philips Magnavox MWC20T6 TV Logo
13 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
tv enciende y alos 3 segundos se apaga
  • Televison & Video
