I have a condensate pump for my ms-a12wa. The problem is the pump has 5 wires that are 110v feeding...
(More)
I have a condensate pump for my ms-a12wa. The problem is the pump has 5 wires that are 110v feeding it and I don't have any info telling me were they go. The directions tell me what each wire is for but not were they go.
On Wednesday my Central cooling system stopped cooling., THe fan is working well. but does not cool...
(More)
On Wednesday my Central cooling system stopped cooling., THe fan is working well. but does not cool We were given a quoute of 2500 for a new one. This one is only a few years old.
To the experts: Before we install the Mr Slim split do we need control wire (3 wire) to run with the...
(More)
To the experts: Before we install the Mr Slim split do we need control wire (3 wire) to run with the line set? The remote controls only the indoor unit correct?
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part...
written by farfield
Typically if you want a circuit completed when energized you use C (Common) and NO
(normally open). This means that the contact will close when...
written by farfield
A low charge diagnosis for instance can be miss read if the evaporator
is iced up or has any ice in or on it. A sticking thermostat, relay,
or...
written by farfield
What I have always been told is if your 24 volt side burns out check
the high volt side if the hi volt side burns out check the low volt
side. A...
written by farfield
If your wondering how to check out your refrigeration
compressor;
Modern Compressors have two operations that have to work
together just to run....
written by farfield
Examine the air filter at the beginning of each cooling and heating season and at the beginning of each day light savings time change. Write the date...
written by farfield
HOW TO CHECK A GOOD REMOTE CONTROL Using Camera or Cellphone Camera, use the camera as your eye point the remote control transmitter to the camera and...
written by bobotfel
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps.
Steps:
1. Add attic insulation....
by wikihow
If your tap water is cool, you can air condition a room with it at minimal cost.
Steps:
1. Obtain a radiator from a small car such as a Honda Civic,...
by wikihow
Steps:
1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing...
by wikihow
Service and Repair, System Maintenance, Advantage Mem... Read More
Service and Repair, System Maintenance, Advantage Member Plans, Replacement & Installation, Guarantees, Air Cleaning and Purification, Duct Sealing, Duct Cleaning, Indoor Air Quality, Heating, Air Conditioning and Indoor Air Quality Products, and Commercial Services for your business.
