General Electric AGN05LH Thru-Wall/Window Air Conditioner
Problems with General Electric AGN05LH Thru-Wall/Window Air...?
Ask our Experts
Chat with a Pro
Tell us why
Share your Experience
Do you recommend the
General Electric AGN05LH...
Problems
& Solutions
Manuals
& Guides
Repair
Service
Reviews
& Ratings
Warranty
& Spec
Troubleshooting and Support
Solved Problems for General Electric AGN05LH Thru-Wall/Window Air Conditioner RSS Feed
View More Results for General Electric AGN05LH Thru-Wall/Window Air Conditioner
Find a Manual
General Electric AGN05LH Thru-Wall/Window Air Conditioner Manuals & Guides
Sorry. We do not have a manual for this product.
You can...
  • Search for manuals of related products.
  • Ask an Expert to find it!
Tips & Tricks
(Post a New Tip)
outside unit fan replacement tip
Your central unit outside condenser motor is gonna someday die, that's a fact of life, will you pay some guy 450 dollars to replace a 75 dollar part?... written by TheMobilian
Ductless Split Air Conditioner Review
Ductless split air conditioning units are the very best thing for some situations. Of course they can be installed in the place of most any central... written by heatman101
Air Conditioner Trouble -Review the Possibilities
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check... written by heatman101
Air Conditioning - Cleaning the Condenser Coil
Air Conditioning works by exchanging heat from inside a building to the outside air. To do this some very basic refrigeration principles... written by heatman101
testesttest
test test tes test written by bstreet
Replace the unit? or Replace the compressor? Split AC or Heat Pump
I had this fellow ask why he couldn't find any thing about id model number for buying a replacement out door ac unit. The answer I game him is part... written by farfield
Relay Wiring tips and tricks Simple circut. What to look/lookout for
Typically if you want a circuit completed when energized you use C (Common) and NO (normally open). This means that the contact will close when... written by farfield
Don't jump to "Its low on charge; because its froze up"
A low charge diagnosis for instance can be miss read if the evaporator is iced up or has any ice in or on it. A sticking thermostat, relay, or... written by farfield
WikiManual
(Post a New Chapter)
How to Keep the Upstairs of Your Air Conditioned Home Cooler
Suffering in summer heat in the upstairs bedroom? Make the most of the air conditioning by following these steps. Steps: 1. Add attic insulation.... by wikihow
How to Build Your Own Air Conditioner
If your tap water is cool, you can air condition a room with it at minimal cost. Steps: 1. Obtain a radiator from a small car such as a Honda Civic,... by wikihow
How to Check Your Air Conditioner Before Calling for Service
Steps: 1. Change your filter regularly. This simple step alone can increase the efficiency of your air conditioner. It will also run less, increasing... by wikihow
Upload Manuals
I need help with
near zipcode:
Please enter your zipcode
Search
Click here to get instant support from our best Experts!
Top Repair Providers for AGN05LH Thru-Wall/Window Air Conditioner
Nationwide | | Website
Service and Repair, System Maintenance, Advantage Mem... Read More
Featured Listing
ARS
Nationwide | 8668003823 | Website
When it comes to air conditioning systems, ARS® pro... Read More
Featured Listing
Rate and Review the General Electric AGN05LH Thru-Wall/Window Air Conditioner
Write a review:
Rate this product:
Would you recommend the AGN05LH Thru-Wall/Window Air Conditioner to your friends and family?
Is it reliable?
Is it easy to use?
Is it a good value?
Find a Warranty
Specifications for General Electric AGN05LH Thru-Wall/Window Air Conditioner
Key Features
Remote Control
Without Remote Control
Dehumidifier
With Dehumidifier Functionality
Cooling Capacity
5150 BTU/hr
Energy Efficiency Rating
9.7 EER
Fan Speeds (Cooling)
AC Type
Thru-Wall/Window
Other Features
Moisture Removal (Pt/h)
1.5
Filter
Rigid/Slide-Out
Air Flow
140 cfm
ENERGY STAR
Without ENERGY STAR®
Swing Louvers
Adjustable Air Outlet Louvers
Dimensions
Depth
15.19 in.
Height
11.13 in.
Width
17.31 in.
Warranty
Warranty
1 Year
Electrical Requirements
Voltage
115
Cooling Ampacity
4.9
Cooling Watts
530
Product MPN
MPN
AGN05LH
Describe your problem:
Top Air... Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
