20 Most Recent
Electrolux Insight EKC6049X Stainless Steel Range Questions & Answers
Ignite grill
You probably need a new light bulb you can go to home depot I don't know if they have it there where you live but I am pretty sure they have light bulbs for your grill thank you for your time :)
How can you take the inner glass out of the cooker
Lets see if we can help.If you open door slightly and look on the top of the door edge,you will see a metal plate going across the full width of the door.If you gently push this towards the inside of the cooker,pushing from each outer edge,it is held in with 2 spring clips.When you have this clip off the glass will just slide up and out for cleaning.The glass will normally be marked for correct replacement, (eg.To Inside and or top).Be very careful when lifting out glass and also look out for little rubber buffers that protect the glass when it is refitted.
Hope this helps.
For some reason my cooker keeps switching itself
It sounds like you are setting a cooking time instead of setting the time of day. The oven wont work until a time of day is set. press the centre button (4x)until a red light flashes in the bottom right corner of the clock if you miss it keep pressing until you cycle through to the rh corner(note clock symbal) press + or - until you get to the right time leave for 12 secs then time locks in and your oven will work. the other flashing lites top left= cooking time bottom left =end time top right =timer function with no oven control. If this does not solve it the timer is faulty and requires replacing. good luck.
