20 Most Recent
Eureka WhirlWind 4381 Upright Vacuum Questions & Answers
Where does the flat 'pre-motor' filter go. Mine
Although the manual says this model shouldn't have one, this one does. The flat perf metal plate goes at the bottom on the filter chamber. The top DOES have to be removed to put it in correctly and that was the problem. The plate had been removed during a prior dis-assembly and I'd forgotten exactly where it came from.
The filter itself fits over the perf metal plate, it's to keep birds and asphalt out of the blower 8-)
Now that the motor bearing are replaced ($5 for the bearings, $60 for a set of Torx and a bearing puller) later, it sounds much better. Of course it took awhile to find the bearing puller that will *just* slip under the bearing on teh short end. That armature is a bit close.
Tanks, Dave
Need instructions to reassemble Eureka vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=12503&thid=680704
Posted by TamiLynn on Jun 18, 2008
I had to completely disassemble my Eureka Whirlwind Lite Model 410 bagless vacuum due to an excessive amount of debris that collected in an inconspicuous spot and now that I've reassembled it sounds like something from the motor is rubbing inside somewhere as if I put it together incorrectly. Do you have any schematics on what the insides should look like so I can put it together properly?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to get the schematics is to contact the Eureka Factory @ the listing I will give you below. Sometimes the owners manual have the schematics in the owners manual but if not they might be down loaded from the factory website or to contact them by phone
And ask for cust serv or the serv tech support or parts for the schematics. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service 1-800-282-2886
Customer Service Dept
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
I don't have any suction
finish cleaning, through the whole air path
usually, by the time that a large clog has built up in the narrow neck behind the brushes,
that is easy to find when the cover plate is removed,
some has also got into the fan impeller,
not so easy to see
and restricts suction
the fan housing is held on the front of the fan & motor with clips, it disassembles easily and the lint and such can be flicked out of the impeller
then the exhaust of the motor to the bag can be likewise cleaned
How to change belt on Eureka Whirlwind
On the top cover, there are holes at the front on both sides, there is a screw on each side in one of the holes. Take the out, and the cover should come off, then you can get to the brush roll and belt.
Eukerka lite speed
There are 2 screws on the top cover, remove those and the cover comes off, then you can get to the brush roll and belt. Inspect the brush roll, make sure the ends turn freely, if not, then replace it also.
Eureka bagless whirlwing lite vacuum cleaner
On the top cover, one on each side will be a screw, take those out and the top cover should come off. While you have it off, check the brush roll to make sure it is turning freely, and replace the belt, they stretch after a short time and will give you problems.
Install filaters
not sure which filters you have ... i will assume you have a replacement cassette micron filter -- goes in the compartment on the front of the vacuum just lift up the handle on the compartment and swing upwards it will pull out like one large piece the filter is on the back. the cassette door will be hinged at the bottom so just pull firmly from the top and snap back in place after replacing the filter. Replacement HEPA filter cartridge --- attaches to rear of Eureka upright vacuum cleaners. Here is a pictorial or changing the filters : http://www.eureka.com/servlet/FindOwnersGuide
Eureka 4469 Vacuum cleaner. How to change the belt on it please?
Question edited for clarity.
The videos show how. Parts in the link
4469 Eureka Victory Upright
Parts Warehouse
https://www.partswarehouse.com > Eureka-4469-Victo...
Eureka 4469 Victory Upright Vacuum Parts, Accessories, & Repair Schematics. Free Shipping Available - PartsWarehouse. ... Belt Cap & Gasket 54376-2 ...
Eureka 4300/4400 Series Parts
EZVacuum.com
https://www.ezvacuum.com > eureka-uprights-parts
Bags, belt, filter, brushroll for Eureka Victory / Victory Whirlwind Upright ... 4387, 4388AT,4440, 4441, 4455, 4460, 4461, 4464, 4465, 4466, 4469, 4470, ...
