20 Most Recent
Trust WB-1400T Webcam Questions & Answers
I need cif single chip
I had the same problem too and tried all kinda solution I cud find on the net for ages...
The solution is simple...but windows dont give the exact problem description.
Infact...in Device manager, u miss a category called "Imaging device".To get that section back and put ur cam to work download the file "sti_ci.dll" from
here.
Extract it, and copy the file to "C:\Windows\System32\" folder and connect back ur cam.Yo get get windows saying device is installed and ready to use.
That worked for me.
If it worked for u, please post it on other forms to help people who r still trying to look for a solution.
Www com 14382 03
hi there
it is my webcam specifications:
5V 500 mA
WWW.TRUST.COM/14382-03
s/n;837018961
i dont know what shall i do?
please guide me step by step for install on my pc with windows 7
my email address is:
[email protected]
thanks
WEB CAMERA DOWNLAD
1st You download Webcam Driver.
WEB CAMERA DOWNLADAfter this install the Webcam driver in the system.Installation of Webcam DriverGo to the control panelClick on the System IconClick on the Hardware TabClick on the Device Manager sSelect the Unknown Device or printer device where yellow Question Marks sign on it.Right click on it and uninstall it.After this go to the top of the device manager and click on scan for hardware changes.Driver installation Wizard start.Brows Your Driver from the Hard Disk and click on next.Driver will be install.
Sorry,you have no video capture hardware
This is indicitive of a driver failure or problem with either the hardware itself or a device conflict with another piece of hardware.
a quick check can be done by going to control panel, system, hardware, device manager.
If you see anything with exclamation marks start there if not then check that your hardware exists in the list
If its not in the list you will need to re-install the drivers / applications software for it.
Remember also that some usb hardware does not like switching to different usb ports which also requires re-install.
If you have it on a usb hub the ensure that the hub has its own power supply and is USB 2.0 not 1.0
Does it work.....
Hello!
Please, make sure your camera is installed:
- Start>right click Computer>Manage>Device Manager
- Try to find your camera in the list of drivers.
- If not there, it is not installed, so in that case go to this link: http://www.trust.com/products/product.aspx?artnr=14382 and download the driver (right bottom of the page>quick links>download driver)
- If there, check if it is marked with yellow triangle: if yes, right click on it and Uninstall, then restart computer and install the camera using the downloaded driver: double click on the driver, and Run>Allow/Continue>plug in the camera if prompted. When installation is done, unplug the camera and restart computer.
3. If you only want to check is your camera works properly: follow the steps from 1., find the camera in the list of drivers, right click on it>Properties>General tab and you will see the information. If you find the camera is not working properly, uninstall it like in 2.b., restart and reinstall the camera following steps provided in 2.b.
Regards!
I have installed the driver
Hi
For downloading the driver for Web cam click hear and enter the image work and click the download file.
After download the driver go to downloaded folder and click the setup.exe and install the driver after reboot you computer, after rebooting plug on you webcam and enjoy
If my solution is solve make you happy give the four thumb
Cheer
Can see myself on webcam but no one else can
Check maybe your Internet Service Provider has blocked some communication ports. In this case you can ask them to unblock them for you or you can use a program like AutoTunnel that will unlock your blocked ports.
Nn riesco ad installare webcam trust
Che operazioni ha eseguito?Le consiglio di andare sul sito del produttore e scaricare i driver per questa webcam (l'indirizzo dove andare ? http://www.trust.com/products/productdrivers.aspx?artnr=14382). Una volta scaricati e installati i driver potr? connettere la webcam e usare le sue funzionalit?.Mi faccia sapere se ha risolto
Webcam working o/k but mic not working
Inspect the webcamera for mic outlets. Usually, prior external webcameras required separate microphones to capture sound. However, inspect the camera for any builtin mic outlets.
Looking for software to use with my Trust Webcam.
Copy this site and paste it in your web browser and hit ENTER.
http://www.trust.com/search/default.aspx?cxt=drivers
to download TRUST Camera drivers.
when you get to the page enter your model number.
Our support is organized by product.
First you will need to find your product.
The easiest way to find your product is to enter the 5-digit item number or (part of the) product name.
The item number and name are both mentioned on the product itself and on the packaging.
Where can I find the item number?
Next, before installing the software, DISCONNECT the camera from the USB port and install the CD Softprogram or the Downloaded program.
When the program asks you to connect the camera to the USB port, THEN DO SO.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
