20 Most Recent
Kenwood KAC-7203 Car Amp Questions & Answers
When the bass hits the
Make sure you have good solid connections on your power and ground wires. Make sure the ground wire is touching bare metal if it is grounded to the chassis.
Wire diagram on how to hook up a amp
google the brand and model number and then look for owner manual online. Should be something there or at the Kenwoodwebsite on it. Ask tech support
Amp wont turn on
Bad Ground
Bad Connection to Power, not getting 12.5 Volts
Or
Remote Lead is Bad
Good Luck!
My red light on my
make sure that you have a good ground, make sure you have the right amp turn on wire, and your power wire is fused, best solution is to have it professionally installed! Amp install is very basic if you are having a hard time with that, I wouldn't attempt to try it or have one of your buddies install it! FRIENDS DONT LET FRIENDS INSTALL!
My kenwood amp wont turn on all the way i just
REMOVE THE RCA INPUTS AND DISCONNECT THE SPEAKERS, THEN POWER THE AMPLIFIER UP WITH THIS NO INPUT, NO SPEAKER LOAD CONDITION. IF IT STILL DOES NOT POWER UP, VERIFY THAT THE POSITIVE AND ESPECIALLY THE GROUND CONNECTIONS, ALONG WITH THE REMOTE CONNECTIONS ARE 100%, THEN TRY AGAIN. IF STILL NOT POWERED UP, MEASURE THE REMOTE WIRE VOLTAGE TO INSURE THAT IT IS NOT LOWER THAN 11 VOLTS. IF YOU CANNOT MEASURE IT, THEN DISCONNECT THE REMOTE LEAD FROM THE AMPLIFIER AND TEMPORARILY INSTALL A JUMPER WIRE FROM THE POSITIVE POWER TERMINAL TO THE AMPS REMOTE TERMINAL WHICH WILL FORCE IT TO TURN ON. IF IS STILL DOES NOT POWER UP, THEN IT WILL HAVE TO BE SERVICED. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
No wiring diagram for amp
+ red power to battery
- black negative cable to body/ground
rem blue remote wire that connects to blue wire
on the back of your cd deck
