20 Most Recent Garmin nuvi 265 Car GPS Receiver Questions & Answers
The traffic receiver is in the car charger cable. The charger should have a red light on if it is getting power. If the light is on and the unit is not charging and you have no traffic, the charger cable is bad. If the light is off, then either the fuse did not fix the problem, blew again, or is somehow not sitting properly in the charger. Another thing you can check is by using the unit in another vehicle. If it works fine there, then the charger is not making good contact with your vehicle outlet for some reason. You will probably have to buy a new traffic receiver charging cable.
Garmin nuvi 265... | Answered on May 10, 2017
I would be tempted to see if the parts themselves are available--any chance something got spilled on the buttons ??
Garmin nuvi 265... | Answered on Nov 06, 2012
Doing a soft reset on the nuvi will usually get the nuvi up and running.
If there is a reset button on the bottom, press and hold it until the nuvi powers back on. If it does not have the reset button on the bottom, slide and hold the power switch to the left for at least 10 seconds.
Also running the Garmin WebUpdater and reloading the latest update will resolve most issues.
Download and Install WebUpdater.
Garmin nuvi 265... | Answered on Oct 11, 2011
Hello burchtree,
Go to recently found and just scroll through there and you should be able to find the address you are looking for. Unless you deleted it from there, then unfortunately you cannot retrieve it as my knowledge. Hope this helps. good luck.
- Joe
Garmin nuvi 265... | Answered on Aug 30, 2011
Welcome to Fixya
Make sure that you are not using usb hub's. Plug in the unit directly to the computer USB port. Try to use different USB port. If same thing happened, this could also be a USB cable issue. Try different USB cable.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Garmin nuvi 265... | Answered on Jun 26, 2011
I will suggest you reset your GPS before trying to update it, to reset your gps, follow this steps, turn off your device. Press down on bottom right corner of the touchscreen, and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press Yes to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
Once the GPS unit is reset, remember to place the device outside where there is a clear unobstructed view of the sky for 15 to 30 minutes in order for it to requires fix to GPS satellites. After this, you ca now try again.
Garmin nuvi 265... | Answered on Jun 22, 2011
Sometimes this happens because the mini USB plug of the charger is not fully pushed into the back of the satnav. It feels like it is but it's not. Pushing it in further may solve the problem.
Garmin nuvi 265... | Answered on Jun 07, 2011
You need to go to Garmins web site the link is below just click the link or copy an paste it in to your web browser here is the link
www.garmin.com
Once you get to Garmins web page look at the top of the page to the right where it says My Garmin. Click on that and then set up a user name and password. After that you can register your new Garmin and download any updates that are available. In order to download the updates you will need a USB cable (his will hook up your Garmin to your computer) if your unit did not come with one you can buy it from the store you bought your unit from, but in all honesty you will get it cheaper on ebay.
I hope this helps you out if it does please give me a Yes on the web page you received this response from. Thank you.
Garmin nuvi 265... | Answered on Apr 07, 2011
You can charge it through your computer. If you connect your satnav to your computer with the mini USB lead it will charge. A full charge takes about 8 hours.
You can charge through your car cigarette lighter socket either. This takes around 4 hours. The first charge should be continuous until it's charged so you might be better using your computer. After that if you plug it into the car it might be enough to keep it topped up depending on how much you use it.
NOTE: Don't start the car with the satnav plugged in. Unplug it first and when you've started the car plug it in then as there may be a surge of power when the car starts which has destroyed many satnavs.
Garmin nuvi 265... | Answered on Mar 21, 2011
If what you say is right it would need at least 10 hours charge with at least 6 hours before you would even be able to see & do anything with it.
Charging with the phone charger will not really work, as the current supplied to a phone is way lower than a GPS. Even if it did charge it would take like 24 hours...
You will have to either get a wall charger or a car charger that you are sure is working and charging and leave the GPS on charge at least for overnite.. It should be Ok next day. If not, then you have a fault with the unit, for whatever reasons.
Garmin nuvi 265... | Answered on Mar 20, 2011
If you have noticed this in your area and your 12v cigarette lighter plug in powered and charging the unit then unit may need a firmware update, do this using garmins WebUpdater Software. Also traffic is not covered in all areas so if your travelling you may be in an ara where this feature is not supported.
Hope this helps!
Garmin nuvi 265... | Answered on Mar 17, 2011
Here is the manual you seek in PDF form.
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
Let me know if this helps.
Garmin nuvi 265... | Answered on Mar 08, 2011
Your GPS came with a USB cord that you use to connect the unit to your computer. Once you connect it, go to the Garmin website at:
https://my.garmin.com/mygarmin/customers/myGarminHome.faces
You will see a link to click on to register the unit. You will first have to register yourself though. Once you do that, the webpage should automatically sense which GPS you have and what the serial number is for the unit. If it does not sense it for you instructions will come up that will guide you to download some software that will help the system to read your GPS. Once that is accomplished the site will also help you update your map if you have a free update coming to you.
Garmin nuvi 265... | Answered on Mar 06, 2011
your nuvi will receive its traffic updates through an FM channel that requires no subscriptions. The receiver is located in the 12v power cable so aslong as you are powered you should receive updates.
Hope this helps!
Garmin nuvi 265... | Answered on Feb 08, 2011
I am not familiar with this particular model, but I just updated a Garmin that I have. If it can be updated you should have a place for a cable to plug in and also into your computer, go to their website,follow the instructions. Works very slick. I do know it will be hooked up to your computer for 30-45 minutes or so to update. Hope this helps, good luck
Garmin nuvi 265... | Answered on Feb 07, 2011
Garmin nuvi 265 Car GPS Receiver Logo
Popular Tags
114 questions posted
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
nuvi Garmin
  • nuvi Garmin
Most Popular Question
lifetime traffic feature no longer
  • GPS
