20 Most Recent Panasonic TH-50PC77U 50 in. Plasma TV Questions & Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Panasonic... | Answered on Oct 31, 2015
Contact the authorized service center. In most cases, a firmware update might be necessary. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Panasonic... | Answered on Jul 19, 2014
Panasonic probably can advise you on availabilty and cost, but you will likely will have to supply the part number.
Panasonic... | Answered on Apr 03, 2014
Mats Electronics 1-800-628-1118 or try EBAY.
Panasonic... | Answered on Oct 15, 2011
Hi bhlewis116,
Yes, the power supply board(where the power cord's directly connected) has fuses. It is a multicolored or white ceramic fuse.
jdvillanueva_130.jpg White ceramic fuse
jdvillanueva_131.jpg multicolored ceramic fuse
To check it on the power supply board, you have to take off the rear cover of your TV. Let the unit unplug from the outlet for 1 hour to drain the voltages from the board before you do the repair.
See the location of the fuses on the picture below.
Check its continuity using the multimeter. If you've found an open one, replace it with same current(ampere) rating that is printed on the fuse itself or on the board.
Jdvillanueva
Panasonic... | Answered on Sep 25, 2011
THE MAIN COMMON PROBLEME ON THESE TVS ARE THE SC BOARD REPAIRE 350
Panasonic... | Answered on May 21, 2010
The first thing you should do is open it up and check for a blown fuse. I have serviced several LCD TVs with blown fuses on their powerboards, and I assume plasma TV's use conventional fuses as well.
You should be able to bring the fuse into radioshack for a replacement.
Panasonic... | Answered on Mar 26, 2010
Panasonic TH-50PC77U 50 in. Plasma TV Logo
26 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
TH Panasonic
  • TH Panasonic
Most Popular Question
please help diagnose problem panasonic
  • Televison & Video
