20 Most Recent
Sony BRAVIA KDL-55XBR8 55 in. HDTV LCD TV Questions & Answers
I have sound but no picture
oh, so that's your problem. I'm willing to bet you have a picture but just no backlight. Now does the screen come on briefly when you first turn the TV on? Or is the screen black at all times?? Turn on the TV, turn off the lights in the room. Take a very bright flash light and shine it one the screen.I bet you see a dim picture. It sounds like you have a backlight problem. Either you are missing 24VDC from the power supply, 3.3VDC "backlight on" signal from the main board, a bad inverter, or a bad backlamp.
Sony Bravia 46 XBR has the input bar stuck at the top of screen.
Unplug the TV for a while and hopefully, that should reset the circuity. If you're using the original remote control, check for the display button and press it.
I would also suggest doing a factory reset if your TV has that feature and if the TV allows you to do it after unplugging it.
I need to remove the back off a Sony Bravia KD-48X81J
The front and back pieces are like a clam shell and are compression fit with tabs into one another. You need to use something like a guitar pick or spudger to separate the pieces. Dont use metal objects due to damage that will happen to the plastic .
How can I watch Netflix on a tv Sony wega that isn’t hooked to the internet. It’s wirelessly connected to Vizio ( smart tv Netflix built in) but I want to be able to watch in a different room
netflix is a 100% internet web site , streaming site.
thus the net in flix.
what did you mean by hooked?\
do you have internet at home at all?
do other things in home work to the internet, like PC or cell phones.
what I can not under stand is (different room) this phase
implies some rooms do work (netflex)
and wifi gets weak if my move any TV farther from the home router
and will fail past 25 feet or more. wifi is super weak through walls
for sure brick, or 2 walls.
if home is small one wifi access point is all you need
if huge home more.
distance matter, TV to router.
no TV model # told. (tells me wifi spec)
if you said my TV works in room 1 but not room 2, wifi;.
it be super more easy to answer.. is this true?
if true , get a tech to upgrade your wifi.
or go wired, Ethernet.(a better home upgrade)
