20 Most Recent Vizio VOJ370F 37 in. LCD TV Questions & Answers
Turns on white i can hear the audio and change through the cable channels with my comcast remote.The vizio remote will turn the tv on & off but none of the other buttons work and the screen remain
tcon board fault. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
11/19/2017 10:00:14 AM • Vizio VOJ370F 37... • Answered on Nov 19, 2017
SAME THING HERE ! SCREEN GOES BLACK AFTER A FEW MINUTES OF PLAY?
YOU GUY'S ARE A REAL JOKE !! PERIOD !!
7/5/2016 9:57:01 PM • Vizio VOJ370F 37... • Answered on Jul 05, 2016
3answers
Vizio lcd sreen fading out.
Well time will tell if this is a true solution but I experienced the same issue. Originally I was able to get the TV to work by turning it off and back on.
After some research I notice the the Vizio FAQ mentions a similar issue for which the solution is to unplug the unit for 3min.
After calling Vizio, they suggested that under the menu option Setup, Picture, Advanced Video Features, I should try turning off Advanced Adaptive Luma and Backlight Control.
3/3/2013 4:00:55 PM • Vizio VOJ370F 37... • Answered on Mar 03, 2013
Suddenly no picture only a
Look through the ventilation slits at the back of the TV with the room lights out. If you do not see white light light bleeding through the back, you have a back light failure. It could be the inverter circuit which lights up the CCFL ( cold cathode fluorescent lamp ). You will need professional help to replace it and could cost you about 70 to 100 $ to fix.
7/6/2011 3:58:23 PM • Vizio VOJ370F 37... • Answered on Jul 06, 2011
When volume is up, there is a humming sound.
The sound is the mains frequency, it's not filtered enough because the filtering capacitors have aged. Very simple fix - just replace the capacitors, it's a 15 minute job. Just make sure the replacements are identical and the solderings are well done.
10/21/2010 10:36:44 PM • Vizio VOJ370F 37... • Answered on Oct 21, 2010
When we watch a movie on our 37
You can zoom in on the picture. But you are most likely watching a movie formatted for wide screen. There are different formats of DVD's. Hope it helps.
8/9/2009 12:09:45 AM • Vizio VOJ370F 37... • Answered on Aug 09, 2009
37 Vizio shtting down at random
Can you list the modules that were replaced thus far without resolving the problem? Also, what exactly is the problem? Does the set work sometimes and not others?
Thanks,
Dan
7/31/2009 9:11:22 PM • Vizio VOJ370F 37... • Answered on Jul 31, 2009
TV made a poping noise and the screen went dark.
a capacitor on the DM or convergance board has fried and will need to be replaced. You can use a multi-tester or capacitor tester to test each one. Also look for black burn marks and swelled or black capacitors
7/9/2009 8:56:29 PM • Vizio VOJ370F 37... • Answered on Jul 09, 2009
My TV has blacked out I have nothing, no sound,no screen, no light from the TV, my cable box is lit, along with my amp box I checked all the wires what is that I need to do now?
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16 https://www.youtube.com/watch?v=kFdVi2ejfzA May 8, 2014 - Uploaded by ShopJimmy.com TV Repair Help for a TV With a Black No Image on the Screen - Troubleshooting ... LG LCD TV REPAIR - NO ...
How to fix vizio black screen - YouTube
? 1:05 https://www.youtube.com/watch?v=Qw1yOtt_KAo Dec 22, 2011 - Uploaded by jay saw Mine keeps saying not support for my 360 with an hdmi but it was just ... Must have been one of those... alternate reality things. We click on a video "how to fix vizio blackout" and get a video of ... Trina Foster In EASY How To REPAIR Black/ Blank Screen LCD HD TV Main Board Repair Replace Vizio ...
Vizio 70" E701I-A3 - Picture went out like *snap* th
9/18/2022 4:36:11 PM • Vizio VO... • Answered on Sep 18, 2022
2answers
Vizio M470NV M-series vizio light on orange will not to white tv does't come on change the power board. same problem. whats the problem?
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
4/27/2016 5:20:30 AM • Vizio VO... • Answered on Apr 27, 2016
Left half screen is white.
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD screen are similar, irrespective of its brand and screen size.
3/6/2016 10:18:11 AM • Vizio VO... • Answered on Mar 06, 2016
Vizio e-470i-ao no picture or sound I can see image with flash light. indictor lite comes on but dies in short time. tv is 3years old
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced.
1/19/2016 5:37:26 PM • Vizio VO... • Answered on Jan 19, 2016
I have a vizio tv...i can see the vizio logo light up but wont turn on...
Corrupted firmware. A firmware update is necessary. Contact any service technician.
1/18/2016 3:35:48 AM • Vizio VO... • Answered on Jan 18, 2016
Can I get HBO GO on this television if it has Netflix and Amazon
If it is a smart tv and you currently have a paid subscription to HBO then the answer is yes.
12/8/2015 5:47:56 PM • Vizio VO... • Answered on Dec 08, 2015
How do i fix no backlight on my vizio lcd?
Inverter board.
11/17/2015 6:49:37 PM • Vizio VO... • Answered on Nov 17, 2015
Vizio VOJ370F 37 in. LCD TV Logo
17 questions posted
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
VO Vizio
  • VO Vizio
Most Popular Question
vizio lcd sreen fading out
  • Televison & Video
