20 Most Recent
Midea MPM-08CR-BB4 Portable Air Conditioner Questions & Answers
I have a midea MPK-10CR.
Many times this unit seems like it is running just fine, but in fact it has a problem...
Most have a freeze sensor that will shut down the unit if the evaporator coil gets too cold...
Now that problem can be caused by a couple of things...
A dirty filter or evaporator coil...
Low freon charge...in this case you have a leak somewhere in the refrigeration system...
Freeze sensor thermistor (probe) or circuit board are bad....
Fan motor not running full speed.....
These are the most common reasons why your A/C would run for a few minutes and then shut down...
heatman101
7/23/2011 7:20:35 AM •
Midea...
Answered
on Jul 23, 2011
I takes like 2 hours
??? an airconditioner making ice??? You sure its not a fridge??
7/14/2011 2:33:18 PM •
Midea...
Answered
on Jul 14, 2011
No water comming into machine
On a portable AC, the only way water can be distributed is by a pump which pumps the water out of the collector tank. Chances are that the impellor inside the pump has stripped or is slipping, therefore not pumping the water. ( that is , I am assuming , this model is an evaporative type cooler?? ) if it is a refrigerated type, there shouldnt be any need for water , however , it will have a condensate pan which catches the water produced by the refrigeration cycle.
7/14/2011 2:32:11 PM •
Midea...
Answered
on Jul 14, 2011
Midea MPK-10CR air conditioner "P2"
If the drip line is raised too high, sometimes the level inside will exceed the trip-point for the pan-level.
Try lowering the drip line so the water runs 'downhill' the whole way. If it still occurs, the sensor in the pan may be stuck.
7/15/2010 5:05:48 AM •
Midea...
Answered
on Jul 15, 2010
