20 Most Recent
Frigidaire FAS256R2A Thru-Wall/Window Air Conditioner Questions & Answers
Unit blows cool air out but doesn't cool room
I have a question, how was the freon checked if the compressor is not coming on. If the compressor is not coming on, make sure it is received the proper voltage, if it has a capacitor make sure the capacitor is good. Also, how clean are the coils on the unit?
Window ac/heater freezes up when using the heater?
This is likely due to a lack of airflow. Make sure that the air filter is clean and that there are no obstructions blocking the air intake or exhaust vents. If this does not resolve the issue, you may need to have a technician come out and inspect the unit for any other potential issues.
Can't change temperature on AC
thats normal its showing ambient when you lower it the number will change to the setting and then will go back to show what the ambient temp as the room gets cooler the temp number will go down and shut off at set temp
