20 Most Recent Amana NED5400TQ Electric Dryer Questions & Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Amana NED5400TQ... | Answered on Aug 14, 2011
The most likely item is the door switch! If that switch is not activated, then everything is cut off.
Amana NED5400TQ... | Answered on Aug 01, 2011
the thermal fuse is bad inside
Amana NED5400TQ... | Answered on Mar 08, 2011
hi check your vent sound like it stopped up jim
Amana NED5400TQ... | Answered on Oct 22, 2010
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
ghkghd
Amana NED5400TQ... | Answered on Sep 29, 2010
Check for a restriction in your exhaust vent. not just behind the machine but all the way to the outside vent,should have good warm airflow at outside vent. With no good air flow you have no way to get rid of the moisture. and all you will end up with is warm moist clothes. this can happen slowley happen over time and next thing you know it takes several cycles to dry the clothes .it cost a lot to dry them this way
Amana NED5400TQ... | Answered on Aug 08, 2010
Check vent for restrictions including pushing dryer too far back on vent.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Amana NED5400TQ... | Answered on Jul 18, 2010
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Amana NED5400TQ... | Answered on Jul 11, 2010
There are videos for disassembling your style dryer at www.appliancehelponline.com/servicemanual.html there are also videos on inspecting and replacing the rollers. You can also enter in your model # for diagrams and illustrations of yout specific model.
Amana NED5400TQ... | Answered on Apr 09, 2010
check your main breaker box first, see if it tripped, if the breaker looks okay then turn off the breaker for the dryer and reset the breaker switch, if this still doesn't work then a fuse has popped on the circuit board.
Amana NED5400TQ... | Answered on Sep 13, 2009
You did not post the model number but there is a belt that wraps around the drum and there is a pulley that keeps the belt tight. If you turn the drum the wrong way, there is an outstanding chance that the belt has slipped off the pulley and there is a not start switch attached to it. Without the model number, that is all I can say.
Amana Dryers | Answered on May 19, 2019
Did you have a problem restarting the dryer after each use? It could be a bad motor or open contact in the timer.I would also check the wiring harness and the plug going to the motor. Hope this helps
Amana Dryers | Answered on Apr 16, 2019
You mean ALE643RBW... drew blanks when I first looked and gave up. So... there's no moister sensor for this model. It runs the cycle by the start point of the timer. Its labled "more" dry or "less" dry in some fashion which merely changes the length of the cycle. Simple and dependable but doesn't meet todays "green" requirements.
Most likely it is the timer which lists at ~$170US from Sears. Your dryer has gotta have some years on it so not sure what else it may need in the near future. If you can do repairs yourself, $80 refurb timer on Ebay Otherwise to pay labor and markup... better off with new.
Amana Dryers | Answered on Feb 17, 2019
Amana NED5400TQ Electric Dryer Logo
Popular Tags
17 questions posted
Top Amana Dryers Experts
Sal De
Marvin
Marvin
jdthefixer
Are you an Amana Dryer Expert? Answer questions, earn points and help others
View Most Popular
Amana Dryers
  • Amana Dryers
Most Popular Question
checked fuse
  • Dryers
