20 Most Recent Kaspersky Labs Business Space Security 6 Full Version for PC, Linux Questions & Answers
I have lost my kaspersky business space security
If you lost the activation code, you should submit a case Kaspersky Support and Services.
To access the link and submit a case for the “Kaspersky Americas Support and Services United States” click here. If you want to change the country which you will submit the case, select that country on the top of the page and find the support page to submit technical support case.
Fill the form and submit case. You will get the answer. This is the only way to get support for the lost activation code.
I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
3/26/2010 3:15:13 PM • Kaspersky Labs... • Answered on Mar 26, 2010
0answers
How to uninstall the kasperskey if you lost the password?
You can uninstall Kaspersky product from your system by using Kaspersky Lab Products removal tool. To check whether this tool is compatible with your Kaspersky product and your operating system, and also to download and execute the tool, you can refer to the following Kaspersky support page: http://support.kaspersky.com/common/service.aspx?el=1464#block1 Hope this will resolve your issue. GuruAid.com
9/10/2018 7:14:57 AM • Kaspersky Labs... • Answered on Sep 10, 2018
Unlock code nokia 5800
YOU CAN GET UNLOCK CODES ON EBAY OR AT A PHONE SHOP
7/18/2015 9:30:02 AM • Kaspersky Labs... • Answered on Jul 18, 2015
Kaspersky lab activetion key
It's in the box or on the cd sleeve
4/13/2014 11:04:21 PM • Kaspersky Labs... • Answered on Apr 13, 2014
When I boot the computer
What it says is that there might be software which acts as a keylogger installed on your computer. Very briefly, keylogger is software which records everything you type on your computer. However, kaspersky sometimes happens to give a false positive and recognize software as keyloggers , whereas they are not. So, try to see where this software is located and check if it really contains a keylogger!
1/26/2014 6:52:07 PM • Kaspersky Labs... • Answered on Jan 26, 2014
Make computer run faster
You can speed up your PC with the help of these tips given below:- 1) Defragment & Optimize files in the hard disk regularly. 2) Disable the unwanted start up programs. 3) Defragment the registry if needed. 4) Uninstall unnecessary programs (Games, crapware, toolbars, etc.) 5) Install latest Windows updates. For task 1, 2 and 3 use reliable program like I always use "RegInOut" for the best performance. Remember that Windows need above to be optimized from time to time. So regular maintenance is required.
12/2/2013 1:42:19 PM • Kaspersky Labs... • Answered on Dec 02, 2013
0answers
My activation code for my kaspersky antivirus wont
I need to know your Kaspersky version to help you with the activation code. In the meantime, search Google using this text: ("kaspersky 2013", torrent) without brackets and select any link with a keygen or serial /code. Then download it with uTorrent and install it.
11/2/2013 4:20:48 AM • Kaspersky Labs... • Answered on Nov 02, 2013
System information shows: System Summary:
if driver problem, go to DeriverMAX and do free downloading by scanning. update what you need.
10/20/2013 6:00:33 PM • Kaspersky Labs... • Answered on Oct 20, 2013
Losing internet connection
First of all I would suggest you that contact with your ISP ( Internet Service Provider ) If they say: everything is fine! then perform these tips to fix your issue:-- Update device drivers.- Check your Preferred DNS address.- Disable Firewall.- If you have Free-trial antivirus then uninstall it.- Uninstall p2p software's (uTorrent, BiTorrent, Team Viewer.)- Optimize internet setting's (must use reliable program PC Fresher for best result.)- Install latest Windows updates.- Restart PC
9/25/2013 9:08:50 AM • Kaspersky Labs... • Answered on Sep 25, 2013
0answers
Slow pc boot up
Press windows button and in the search type msconfig go to startup tab and uncheck those you dont want to start. scroll to the bottom toolbar bottom of screen right click you can select task manager applications also processes you will see whats running on your computer and ticking over you might have a virus http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 if you see something running that you does not need to be running select end now then you might you might uninstall that particular program and some unnecessary programs you should also check leads from motherboard to hard drive for secure dust free connections click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes this will schedule to on restart do not have any input while chkdsk utility is in progress any might damage your computer also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/ then defragment your hard drive adding more ram is the best way of speeding up a computer If youre not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules you should always ask for a guarantee on compatibility before purchasing any ram and buy working pairs if possible you might have to many programs running at the same time putting to much strain on the CPU central processing unit try uninstalling a few unnecessary programs This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Open Disk Cleanup by clicking startall programsaccessoriessystem tools and then clicking Disk Cleanup. In the Disk Cleanup Options dialog box, choose whether you want to clean up your own files only or all of the files on the computer. If you are prompted for an administrator password or confirmation, type the password or provide confirmation. If the Disk Cleanup Drive Selection dialog box appears, select the hard disk drive that you want to clean up, and then click OK. Click the Disk Cleanup tab, and then select the check boxes for the files you want to delete. When you finish selecting the files you want to delete, click OK, and then click Delete files to confirm the operation. Disk Cleanup proceeds to remove all unnecessary files from your computer. This tool deletes unnecessary or temporary files on your hard disk so you can increase the amount of storage space you have. Delete the files using Disk Cleanup If you want to reduce the number of unnecessary files on your hard disk to free up disk space and help your computer run faster, use Disk Cleanup. It removes temporary files, empties the Recycle Bin, and removes a variety of system files and other items that you no longer need. Watch the demo (1:00) this should speed up your computer
7/31/2013 9:03:11 PM • Kaspersky Labs... • Answered on Jul 31, 2013
Where can i get mastering machine learning Tips for Tackling Assignment
Mastering Machine Learning: Tips for Tackling Assignments Conquering machine learning assignments requires a blend of theoretical understanding, practical application, and strategic problem-solving. Here are some tips to help you excel:Foundational Knowledge: Solid Understanding of Concepts: Ensure you grasp the core concepts like supervised vs. unsupervised learning, different algorithms (regression, classification, clustering, etc.), and their applications. Mathematics and Statistics: Brush up on essential math and statistics, including linear algebra, calculus, probability, and statistical distributions. Programming Skills: Hone your programming skills in languages like Python or R, including libraries like NumPy, Pandas, Scikit-learn, and TensorFlow.Tackling Assignments: Thorough Understanding: Carefully read and understand the assignment instructions and objectives. Identify the specific problem you need to solve and the expected deliverables. Data Exploration and Preparation: Analyze the provided data: Understand the features, data types, missing values, and potential biases. Data Cleaning and Preprocessing: Address missing values, outliers, and inconsistencies. Feature Engineering: Create new features or transform existing ones to improve model performance. Model Selection and Training: Choose appropriate algorithms: Select algorithms based on the problem type (classification, regression, etc.) and data characteristics. Model Training: Train your model on the prepared data and tune hyperparameters to optimize performance. Evaluation: Evaluate your model's performance using metrics like accuracy, precision, recall, F1-score, or AUC-ROC curve. Experimentation and Iteration: Try different algorithms and hyperparameter settings: Compare the performance of various models to find the best fit. Cross-validation: Use techniques like k-fold cross-validation to assess modelgeneralizability and avoid overfitting. Regularization: Apply regularization techniques like L1/L2 to prevent overfitting and improve modelgeneralizability. Interpretation and Communication: Analyze results: Understand why your model performs well or poorly and identify areas for improvement. Visualize results: Use plots and graphs to illustrate your findings and insights. Clear Communication: Present your results and explain your approach in a clear and concise manner.Resources for Learning and Support: Online Courses: Platforms like Coursera, edX, Udemy, and Udacity offer comprehensive machine learning courses. Books and Tutorials: Numerous books and online tutorials cover machine learning concepts and techniques. Open-Source Libraries and Frameworks: Explore libraries like Scikit-learn, TensorFlow, PyTorch, and Keras for implementing machine learning models. Community Forums and Q&A Sites: Seek help and engage in discussions on platforms like Stack Overflow, Reddit's Machine Learning subreddit, and Kaggle forums. University Resources: If you're a student, leverage university resources like libraries, workshops, and professors' office hours. Remember: Practice is key: The more you practice, the better you'll understand the nuances of machine learning and improve your problem-solving skills. Start with simple projects and gradually increase complexity. Don't be afraid to experiment and try different approaches. Seek help when needed and learn from others' experiences.
4/24/2024 9:45:52 AM • Computers &... • Answered 2 hours ago
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered 7 hours ago
Kaspersky Labs Business Space Security 6 Full Version  for PC, Linux  Logo
Popular Tags
3 questions posted
Top Kaspersky Labs Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
Julie Clark
Julie Clark
Are you a Kaspersky Labs Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Kaspersky Labs Computers & Internet
Most Popular Question
lost kaspersky business space security
  • Computers & Internet
