20 Most Recent
Hobby Zone Hobbyzone Super Cub Propeller Rc Airplane Questions & Answers
Elevator on tail will not move after accident
EITHER YOUR ELEVATOR CONTROL CABLE IS BENT OR MISSING, OR THE ELEVATOR ACTUATOR SERVO IS NOT FUNCTIONINGNOTE:**** CHECK ALL OPERATIONS BEFORE TAKING TO THE AIR AGAIN...IT GETS COSTLY!!!
I assembled my new Super
G o back to your manual. I had this problem also. The procedure must be followed properly. First, make certain your throttle is in the off/down position. Second, turn on transmitter. Third connect battery. Once you place the battery in the enclosure and lock the cover you should be working properly. Last but not least, when finished flying, remove the battery BEFORE powering off your transmitter. You must follow these steps. You can NOT leave the battery in the plane when not in use.
How do I replace the motor for the hobbyzone cub
there are some motor mounts offered for super cub which will fit exactly the holes on the nose of the plane just google it. There is a kit offered on ebay with esc and receiver. I believe 1000 kv would be enough for the plane especially with the floats it might need more power although the bigger propeller that comes with the floats would be sufficient. Personally I would change the motor only if necessary, although my receiver broke and I think i will change everything on the inside. hope to have answered your questions partly
Can someone tell me how
Pull spinner off by placing finger tips under lower edge of spinner between where prop comes out and pulling straight off. The spinner on tight so it takes quite a bit of pressure. The plastic is quite strong so don't worry about breaking it.
10/23/2011 11:47:19 PM •
Hobby Zone...
Answered
on Oct 23, 2011
My fuselage broke in two
you can use an epoxy that is just for foam purposes. But mine broke at the center under the wing. I used colored duct tape to match and it flys just fine.
How do we replace propeller on super cub?
The spinner is simply pressed on. Pull the spinner directly forward while firmly holding the plane at the firewall. Once removed hold the prop by hand and use a wrench to loosen the prop nut. The propeller should slid off but may need to be unscrewed.
To re-install, just reverse procedure. The prop needs to be firm or snug only. Do not over tighten. Be sure to press the spinner back on lined up with the prop blades. Then go fly
Is a 11 8 prop the same as a 12 6 prop
Depends on whether or not the engine your running can handle the extra spin load of a 12/6. Here's a chart of interchangeable props based on engines and their capabilities and not on thrust characteistics. The longer blades cause more centrifugal force and drag, and will result in slower top engine speeds.
http://www.wcrcskyhawks.com/rcinformation/Prop_Charts.pdf
They're similar but you have to be up to at least a .70 to run them and you didn't include any engine info.
Fisher-Price J7485 T-Rex stopped moving
Check Batteries: Ensure that the batteries are properly inserted and have sufficient charge. Sometimes, a low battery can cause the toy to stop functioning.
Switch On/Off: Confirm that the toy is switched on. Some toys have an on/off switch or button that might accidentally get turned off.
Connections and Wires: Inspect the wires and connections inside the toy. Loose wires or faulty connections can lead to malfunction.
Obstructions: Look for any obstructions or debris that might be preventing the T-Rex's movement. Clear any blockages.
Reset: If there's a reset button, try pressing it. This can sometimes resolve minor issues.
Contact Customer Support: If none of the above steps work, consider reaching out to Fisher-Price customer support as below.
https://service.mattel.com/us/ContactUs.aspx
2/22/2024 2:51:59 PM •
Toys
Answered
on Feb 22, 2024
