FixYa.com
Panasonic CW-C52RU Air Conditioner
All Products > Panasonic > Air Conditioners
Problems with Panasonic CW-C52RU Air Conditioner?
Search inside Panasonic CW-C52RU Air Conditioner Knowledgebase
Troubleshooting and Support
Solved Problems for Panasonic CW-C52RU Air Conditioner RSS Feed Post a New Problem
Will constantly running a central AC...
Will constantly running a central AC system on a very cold setting, such as 65-F, damage the system?
1 Solution
What would cause the outside part of my...
What would cause the outside part of my air conditioner to frost over?
1 Solution
How do i know if my cooling system can be...
How do i know if my cooling system can be repaired or if it is time to replace it?
1 Solution
How often should you change the filter on...
How often should you change the filter on your heating and AC unit?
1 Solution
How much does a mid-price range central AC...
How much does a mid-price range central AC cost installed with an electric heater including ducting in a 1300 square...
1 Solution
I am looking for a digital thermostat that...
I am looking for a digital thermostat that can run two AC units simultaneously or is there another solution using one...
1 Solution
Heat pump trips circuit breaker
The heat pump in my air conditioning system trips the circuit breaker... what do I do?
1 Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Other Features
Moisture Removal (Pt/h)1.7
ENERGY STARWithout ENERGY STAR®
Key Features
TypeThru-Wall/Window
Remote ControlWith Remote Control
Cooling Capacity5000 BTU/hr
Energy Efficiency Rating10 EER
Fan Speeds (Cooling)2
Dimensions
Depth12 in.
Height13.94 in.
Width18.91 in.
Warranty
Warranty1 Year
Panasonic Contact Information
Main support number800-211-PANA
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
