20 Most Recent
Buck Ford F250 F350 2002 02 Radio/stereo Wire/wiring Harness Questions & Answers
Radio code ford
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers
on any labels,barcodes or stamped in the metal casing
I am baffled as far as wireing the new harness to
Did you happen to look into buying a wire harness adapter? The sell them fairly cheap at Auto Parts Stores. (approx. $20-$25) It is very easy, as well as making sure it is correct. Otherwise you are taking risks of many types. Such as, electrical issues, sound issues, etc. Just a suggestion.
Windshield wipers keep stopping
Same thing happened in my dads F-250. First, I would say check the wiring. Could be a short. If not the wiring, the little motor for the wipers could be going bad. Not a very expensive fix either way.
No power to fuel pumps, or to 10 amp fuse (for fuel tanks).
try the fuel cut off switch, its a yellow rocker switch that when the vehicle gets into an accident or recieves major shock will disengage power to the fuel pump/thus no power im not sure of location on the trucks,my best guess would be glove box or passenger kick-panel area it will be marked as fuel shut-off
I have a 1995 f250 it had a tape factory player
yes. more that likely if you look at the stereo it will give you a colour code as to what colour wires do what. if they dont then a simple google search for a stereo wiring diagram for each vehicle will be even better. if its just your speakers that are messed up then a neat trick to remember is if you take a AA battery and put the + side of the battery to the + side of a speaker wire and the - to the - then that speaker will come out. If the poles are backwards then the speaker will go in. good luck
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
