20 Most Recent
Buck Honda Prelude 1999 Car Stereo/radio Wire/wiring Harness Questions & Answers
I just got a 1999 Honda prelude and I had to
the code you can from a honda dealer and if you are going to replace it you are going to have rip the whole radio console out and custom build the new radio into the space which be smaller to fill the space so it does not look like someone broke into your car and left with big hole in your dash board
I am replacing the radio in my '97 chev silverado
easy fix is to go to a car audio retailer such as best buy an pick up a wire harness adaptor they generally cost 10 to 15 bucks this will save you the hassle of tracing down the wires however general wires are red-power black-ground blue remote amp turn on eight of the wires are for the front and rear speakers thier colors are paired an example would be solid green and then green with a black line these two wires are for one speaker +/- connections you can connect on speaker one at a time and then use the balance and fader control on the radio to check which wire are for front/rear and left/right speakers the factory radio has extra wires which usally control power antena,and dimmer switch for when you turn the headlights on
How do i can unlock my stereo forgot the codes?
Unfortunately Honda codes are only available from the Main Dealer or
by using a Radio Decoding Service who will connect a laptop to read the
working code inside your radio`s memory chip (EEPROM)
I got an old casette radio from honda
I would suggest going to the library and looking up a wiring diagram for your radio. The negative is probably the case (not 100% sure of this).
Good Luck,
Gilshultz
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
