20 Most Recent Panasonic ER 203 Beard Trimmer Questions & Answers
I have purchased ER203 6 Years back now its not working i found battery end life, can i use this battery AA 1.2V 1300mAH for this trimmer, can i charge above battery as it is like ER203, Please suggest
Panasonic ER 203... | Answered on Apr 28, 2014
If the spring on the blade has come out, the blade has to be broken. The manufacturing process for this type of blade makes it impossible to take it apart without breaking the plastic that holds the spring. There is simply no way to effectively repair the blade.
You will need to replace the blade or the entire unit.
Panasonic ER 203... | Answered on Mar 13, 2014
poor website to get any helpful information, don't waste your time
Panasonic ER 203... | Answered on Jun 09, 2013
I am also found
Panasonic ER 203... | Answered on Nov 14, 2012
BATTERY MODEL NUMBER: WER203L2508
Panasonic ER 203... | Answered on Nov 18, 2011
Your Trimmer uses Ni-cd battery, which provides 40 minutes of shave time with one full charge of 8 hours. It seems that either your battery is dead or the cutting element is clouged. I'd suggest that you wash the cutting elements with warm soupy water and then try to turn it on again.
If that doesn't work, your battery is probably dead. If the unit is within warranty, you can contact Panasonic support for a replacement or else try replacing batteries with the help of a local technician or a repair center.
Hope this helps..
Panasonic ER 203... | Answered on Mar 06, 2011
If you open the set you can find a battery pack which is mae for the panasonic shaver. But for replacement you can put along the available ones inthe market by looking at the voltage and amperage. The curent (amp) factor is most important as this is what drives the motor for the time period.
There are also many models of the AAA or AA that can be suited to fit the space to give this VA rating.
Panasonic ER 203... | Answered on Sep 17, 2010
just insert a thin bladed knife between the two parts and gently lever apart
Panasonic ER 203... | Answered on Jun 10, 2009
Panasonic ER 203 Beard Trimmer Logo
22 questions posted
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
gautam jha
Level 1 Expert
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Health & Beauty
Most Popular Question
blade come out iam unable reinsert
  • Health & Beauty
