20 Most Recent Accutek AOJ-1601 Stand (Pedestal) Fan Questions & Answers
There is an 'enter' side and a 'blower' side to each fan. Is it spinning the proper way?
Accutek AOJ-1601... | Answered on Jul 02, 2015
Probably twists off.
Accutek AOJ-1601... | Answered on Oct 03, 2013
clean your fan motor. remove carefully part by part(your fan motor, the coil and the rod). remove all the dirt. put machine oil at the rod, front and the back part. try to spin it. oil it and spin, do it again and again until the rod spin smoothly. and then put back those part as before you 'open' the fan. but remember, do not do this while your fan plug is still plugged to the power source. or you will be dead instantly. for your safety, you know. so be careful. last step, try it! :) i hope this will help you in fixing the fan.
Accutek AOJ-1601... | Answered on Mar 30, 2013
1st, remove the poer cord from your fan and determine if you have any breaks in the line by checking the voltage ( 120 volts) coming from the bare wires when it's plugged in. If nothing registers on your volt-multimeter, you can easily repair the cord or just replace it. Check to see if that works, and if not, ask me the next step.
Accutek AOJ-1601... | Answered on Sep 21, 2012
there will be a oscillation driving counter wheel present inside it which is made of plastic tat would have got damaged or broken so replace the wheel then ur fan will start oscillating
Accutek AOJ-1601... | Answered on Nov 29, 2011
That means the bearings are dry and have locked. Simply open the motor cover by removing the screw and pull the oscillation knob by rocking it side by side gently to have free access to the motor.
MAKE SURE THE FAN IS UNPLUG FIRST. Use cream type grease on both ends of the shaft. After applying the grease rotate the blades until they're freely and you feel the blades have released.
Place the motor cover back and the oscillation knob and plug-in the fan. Leave it on HIGH for 10-minutes or more to make the rotor loose with the grease.
Accutek AOJ-1601... | Answered on Jun 12, 2011
Sounds like the shaft & bearings are gummed up. Clean them up with Liquid Wrench or WD - 40 (sparingly) spinning the shaft by hand to get it inside the bearings, front & rear. You should feel it loosening up. Then remove as much as you can with a cloth while spinning the shaft. Then relube with 3-in-1 oil. --- Oil alone will not cut thru the gum. Remember WD - 40 and Liquid Wrench are not lubricants!! You must use 3 -in-1oil or the likes.
Accutek AOJ-1601... | Answered on Dec 03, 2010
Accutek AOJ-1601 Stand (Pedestal) Fan Logo
31 questions posted
Top Accutek Dryers Experts
Marvin
Marvin
ray gallant
ray gallant
 Russ Hill
Russ Hill
Are you an Accutek Dryer Expert? Answer questions, earn points and help others
View Most Popular
Accutek Dryers
  • Accutek Dryers
Most Popular Question
accutek aoj 1601r fan wouldnt start
  • Dryers
