20 Most Recent
Franke FF-303 Kitchen Faucet with Pull-Out Spray Chrome/Black Questions & Answers
Hello i have a franke kitchen faucet #fff303 and
There are websites that give instructions for disassembling the Franke faucets. Also, some have a valve cartridge ($20-50) that can be replaced (you take the handle off, the catridge is inside)/
Franke pull out spray broken
check to see if the weight on the hose got shifted too far back (if it was loose it could slide along the hose).
It sprays fine but off
One of the greatest things about Franke Faucets is that they have a lifetime guarantee. If you recently changed the waterlines in the home then more than likely when the water was turned back on or lines pressurized the settlement in the water main (Outside of your home) was activated and clogged the aerator. Most aerators simply turn counter clockwise (With the water off) after remooving the aerator simply clean and dislodge any particles in another sink. As for the pull out, some models have an inline screen located between the hose and the faucet handle. Simpy remove the handheld faucet (With the water off) and clean the screen.
Trouble with a Franke kitchen faucet
Look at the clutter under the sink. Is the hose tangled or caught on something? There should be a weight clamped to the hose to make it fall back into place. This weight minght have slid down the hose.
Drain stopper is stuck
try turning the top of stopper with fingers. They are generally " locked in with a twist" and can be unlocked the same way. good luck!
9/1/2014 5:03:00 AM •
Franke Home
Answered
on Sep 01, 2014
Franke plug seal problem
Adjust the clip underneath the sink to a different hole on the rod so it will tighten more when used.
5/1/2014 3:07:04 PM •
Franke Home
Answered
on May 01, 2014
The half bowl of our
Replace the drain and plug with a new one while using silicone to seal the upper and lower half of the drain.........It is also a good practice to lubricate the rubber washer as well...........Wait 24 hours and it should be good to ge........Hope this helps.
3/25/2014 7:15:41 PM •
Franke Home
Answered
on Mar 25, 2014
