20 Most Recent
Toto CST743S-04 Drake Suite Two Piece Round Toilet - Gray Questions & Answers
When I flush the toilet does flush fine but it
new quality flush valves are inexpensive. suggest you buy a new one at a big box store (Lowe's e.g.) . easy to install, just follow the directions.....a Fluid Master or Gorkie should work fine...$25 or less, probably less.....
Toto Neorest 600 issue of low water pressure
page 35 of your instructions. Don't have it, here is a link copy and paste
https://www.totousa.com/filemanager_uploads/product_assets/OwnersManual/0GU9001R_NEOREST_600_EN_OM.pdf
7/8/2023 3:46:16 PM •
Toto Home
Answered
on Jul 08, 2023
Toto washlet s300 has developed slow leak from behind brass connection and plastic.
If you are able to identify the source of the leak, you may be able to fix it yourself. If the leak is coming from the brass connection, you may need to replace the connection or tighten it. If the leak is coming from the plastic, you may need to replace the plastic part or use a sealant to stop the leak. If you are unable to identify the source of the leak, it is best to contact a professional plumber to help you diagnose and repair the issue.
3/16/2023 9:59:53 PM •
Toto Home
Answered
on Mar 16, 2023
The stream on "Rear" is weak on my new Toto Washlet GL since I got it 1 week ago. The "Soft Rear" setting works OK, but the normal Rear wash is no stronger than the "Soft" setting.
It sounds like you may have a problem with the water pressure for the rear wash setting on your Toto Washlet. Here are a few things you can try to troubleshoot the issue:
- Make sure that the water supply hoses for your washlet are securely attached and not kinked or clogged.
- Check the water pressure at the source (e.g., the wall outlet or the valve under the sink). If the water pressure is low, that could be the cause of the weak stream.
- If the water pressure is fine, try cleaning the nozzle for the rear wash setting. Sometimes debris can accumulate in the nozzle and cause the stream to be weak.
- If none of these troubleshooting steps help, you may need to contact Toto customer service for further assistance. They should be able to provide you with additional guidance or arrange for a service technician to come and check your washlet.
1/6/2023 8:31:31 PM •
Toto Home
Answered
on Jan 06, 2023
The lever (handle) to flush
I had this issue as well with my toilet. My chain was unattached and had been sucked down the drain under the
stopper valve preventing the toilet stopper valve from completely
closing and causing the water to continually run. After re-attaching the
chain I noticed when I flushed the toilet that the handle did not rise
again until I manually pushed it up. After readjusting the chain to a
tighter position where the chain was not floating at all but instead
holding the stopper valve in place I again flushed to check the
reaction. This fixed the issue of the water continually running and also
the handle not resetting itself properly.
Here is the steps I took to resolve my issue:
Step 1: Remove the lid off of the tank.
Step 2: Check to see if the chain coming from the Toilet Handle to the Stopper Valve is loose, unattached, or broken.
Step 3: Flush the toilet and check to see if the problem has been fixed. If not readjust the chain to a different position and flush again.
Step 4: If all is resolved replace the tank lid.
Other possible things to check:
Check the Float Ball to see if it's Half-way or more submerged in the water. If it is it needs to be replaced.
I hope this helps!
8/28/2018 11:34:29 PM •
Toto Home
Answered
on Aug 28, 2018
