20 Most Recent Milwaukee 0824-24 V18 1/2" Hammer Drill Kit Lithium-ion Questions & Answers
When I was done using the hammer drill to drilling
open your chuck as far as it will go look down inside the chuck and you should see where it has come from ,if that is where it came from it will be right hand thread probably allen key or very small socket
8/15/2009 7:54:53 AM • Milwaukee... • Answered on Aug 15, 2009
I need instructions on how to wire a new switch to an old drill; Milwaukee Magnum s/r 053242842. Listed 480A
These videos should help, they all work to a theme.
7/21/2023 11:07:57 PM • Milwaukee Drills • Answered on Jul 21, 2023
Which side is hot and which side is ground on a 9.6 volt 18 volt Milwaukee universal charger?
There is help and videos in the link, but you can easily check the contacts with an analogue multimeter. You don't say WHY you want this information? https://www.google.com/search?q=18+volt+universal+charger+milwaukee+wiring+diagram ..
4/4/2023 3:19:09 AM • Milwaukee Drills • Answered on Apr 04, 2023
How do I take out the spindle on a 1675-1 Milwaukee hole hawk drill
To remove the spindle on a Milwaukee Hole Hawg 1675-1 drill, you will need to follow these steps:
  1. Disconnect the drill from the power source and remove the chuck key.
  2. Turn the drill over so that the chuck is facing upwards.
  3. Locate the spindle lock button on the side of the chuck.
  4. Press the spindle lock button and hold it down while rotating the chuck counterclockwise to loosen it.
  5. Once the chuck is loosened, you can remove it from the spindle by pulling it off.
  6. To remove the spindle from the drill, you will need to loosen and remove the retaining bolt that holds it in place. The retaining bolt is typically located on the bottom of the drill, near the front of the spindle.
  7. Once the retaining bolt is removed, you should be able to lift the spindle out of the drill.
It is important to follow these steps carefully to avoid damaging the spindle or the drill. If you are having difficulty removing the spindle, you may need to consult the owner's manual or a certified mechanic for assistance. They will have the necessary tools and expertise to help you remove the spindle safely.
1/8/2023 5:07:44 AM • Milwaukee Drills • Answered on Jan 08, 2023
My Milwaukee cordless drill has a full battery and the trigger works and the truck works but it won't turn right or left at all
How did we go from a Cordless drill and battery to the steering on a truck?? :>D
12/6/2022 7:17:04 PM • Milwaukee Drills • Answered on Dec 06, 2022
How do i replace the spindle assembly in my milwaukee 0235-1 drill ?
copy and paste https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/milwaukee/electric-drill/0235-1-serial-755-70423-milwaukee-electric-drill-driver-parts/1-2-keyless-chuck-magnum-drill
6/30/2022 4:46:56 AM • Milwaukee Drills • Answered on Jun 30, 2022
I have Milwaukee m18 drill that won't tighten down.
There are some youtube videos on how to replace the chuck and there are several sources for chucks.
4/23/2022 10:29:16 PM • Milwaukee Drills • Answered on Apr 23, 2022
2answers
I have a Milwaukee cordless drill/ driver cat#2801-20 will not work but the flash light will work
The battery is not fully Charged. Please charge for 4 to 5 hours. The flash light works because it requires lower voltage than drill/driver to work.
3/9/2022 9:39:23 AM • Milwaukee Drills • Answered on Mar 09, 2022
How to clean M18 milwaukee impact
Tec7gt7 ( recommend spray ) electrical safe for switch and motor commutator. for novice and expert. do not use wd40. Use if very dirth A cold degreaser for only cleaning the 2 housing parts
9/16/2020 9:03:25 AM • Milwaukee Drills • Answered on Sep 16, 2020
I am looking for a replacement switch for a Milwaukee 3/8 drill model 0222-1?
I always use a tool reviews site before I purchase anything nowadays. For me the best is https://toolinspector.com
12/13/2019 8:22:59 PM • Milwaukee Drills • Answered on Dec 13, 2019
2answers
Milwaukee 12v hammer drill/driver stuck in hammer mode model 2408-20
If nothing's broken, you can usually apply and hold pressure in the direction you want to the switch or ring, depending on which model you have, and lightly press the trigger to get it to move.
11/23/2019 3:43:06 PM • Milwaukee Drills • Answered on Nov 23, 2019
Milwaukee brushless drill / driver (2801-20) that will not work it fell into water
If the circuit board is damaged, you can contact the manufacturer and possibly get a new circuit board. It would be good news if it were under warranty --maybe. Immediately after immersion and retrieving it, one might try blow drying it (or drying it with a heater). But you can't let it sit around and dry on its own. Chances are, you are fated to get another drill.
10/22/2019 4:52:50 AM • Milwaukee Drills • Answered on Oct 22, 2019
Why does my Milwaukee m18 red lithium xc cordless hammer drill only work if I loosen my brush cover (4 screws) ?
Sounds like the brushes may be worn unevenly and one (or both) are jamming at an angle against the armature. They may need replacing.
7/13/2019 8:55:13 PM • Milwaukee Drills • Answered on Jul 13, 2019
I have a milwaukee 1675-1 hole hawg and the switch is bad and was wondering is there a way to test the motor to make sure it is good
Hi, You can bypass the switch with jumper to connect the motor.
3/17/2019 10:15:40 AM • Milwaukee Drills • Answered on Mar 17, 2019
New milwaukee hole hawg only clicks and the light comes on
take it back to where you bought it from. They can show you what to do or replace it if faulty.
2/25/2019 4:55:35 AM • Milwaukee Drills • Answered on Feb 25, 2019
3answers
Milwaukee tools where to buy
Any major hardware store
12/23/2018 5:48:30 PM • Milwaukee Drills • Answered on Dec 23, 2018
Milwaukee 0824-24 V18 1/2" Hammer Drill Kit Lithium-ion Logo
1 questions posted
Top Milwaukee Drills Experts
vince
john h
Are you a Milwaukee Drill Expert? Answer questions, earn points and help others
View Most Popular
Milwaukee Drills
  • Milwaukee Drills
Most Popular Question
when done using hammer drill drilling
  • Drills
