20 Most Recent
Milwaukee 2690-24 18-Volt Hammer-Drill, Sawzall Reciprocating Saw, Circular Saw, and Worklight Combo Kit Questions & Answers
My keyless chuck will not
Open the chuck and see if the screw inside the chuck has backed out. The screw is left hand thread so you will need to turn it to the left to tighten it. It may be an allen or Torx head screw.
7/18/2011 10:16:19 PM •
Milwaukee...
Answered
on Jul 18, 2011
How do I take out the spindle on a 1675-1 Milwaukee hole hawk drill
To remove the spindle on a Milwaukee Hole Hawg 1675-1 drill, you will need to follow these steps:
- Disconnect the drill from the power source and remove the chuck key.
- Turn the drill over so that the chuck is facing upwards.
- Locate the spindle lock button on the side of the chuck.
- Press the spindle lock button and hold it down while rotating the chuck counterclockwise to loosen it.
- Once the chuck is loosened, you can remove it from the spindle by pulling it off.
- To remove the spindle from the drill, you will need to loosen and remove the retaining bolt that holds it in place. The retaining bolt is typically located on the bottom of the drill, near the front of the spindle.
- Once the retaining bolt is removed, you should be able to lift the spindle out of the drill.
It is important to follow these steps carefully to avoid damaging the spindle or the drill. If you are having difficulty removing the spindle, you may need to consult the owner's manual or a certified mechanic for assistance. They will have the necessary tools and expertise to help you remove the spindle safely.
How to clean M18 milwaukee impact
Tec7gt7 ( recommend spray ) electrical safe for switch and motor commutator. for novice and expert. do not use wd40.
Use if very dirth A cold degreaser for only cleaning the 2 housing parts
Milwaukee brushless drill / driver (2801-20) that will not work it fell into water
If the circuit board is damaged, you can contact the manufacturer and possibly get a new circuit board. It would be good news if it were under warranty --maybe.
Immediately after immersion and retrieving it, one might try blow drying it (or drying it with a heater). But you can't let it sit around and dry on its own. Chances are, you are fated to get another drill.
